Salta al contenuto principale
HKC P776A Screen Replacement
Cosa ti serve
  1. HKC P776A Screen Replacement, Separating Digitizer and Case: passo 1, immagine 1 di 1
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Screen Replacement: passo 2, immagine 1 di 2 HKC P776A Screen Replacement: passo 2, immagine 2 di 2
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Screen Replacement, Separating the Screen and Digitizer: passo 3, immagine 1 di 2 HKC P776A Screen Replacement, Separating the Screen and Digitizer: passo 3, immagine 2 di 2
    • Use your fingers to pop the screen out from the digitizer.
  4. HKC P776A Screen Replacement, Removing the Optical Cord from the Motherbaord: passo 4, immagine 1 di 1
    • With the plastic opening tool, lift the black latch up.
  5. HKC P776A Screen Replacement: passo 5, immagine 1 di 1
    • Pull the optical cord out from the motherboard.
Conclusione
USF Tampa, Team 7-6, Remmell Winter 2015 Membro di USF Tampa, Team 7-6, Remmell Winter 2015
USFT-REMMELL-W15S7G6
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 219
