Cosa ti serve
Insert the plastic opening tool between the digitizer and the case.
Place the spudger in the gap created by the plastic opening tool to assist in separation.
Use your fingers to pop the screen out from the digitizer.
With the plastic opening tool, lift the black latch up.
Use the tip of the spudger to release the latches on the motherboard.
Attrezzo utilizzato in questo passaggio:Desoldering Pump$3.99
Suck up the leftover solder using the desoldering pump.
Remove the wifi antenna from the motherboard.
Insert the plastic opening tool between the battery and case.
Apply leverage to break the glue that is attaching the battery to the case.
Using the screwdriver, remove the four 4mm by 1.5mm screws that are attaching the motherboard to the case.
