Salta al contenuto principale
HKC P776A Motherboard Replacement
Cosa ti serve
  1. HKC P776A Motherboard Replacement, Separating Digitizer and Case: passo 1, immagine 1 di 1
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Motherboard Replacement: passo 2, immagine 1 di 2 HKC P776A Motherboard Replacement: passo 2, immagine 2 di 2
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Motherboard Replacement, Separating the Screen and Digitizer: passo 3, immagine 1 di 2 HKC P776A Motherboard Replacement, Separating the Screen and Digitizer: passo 3, immagine 2 di 2
    • Use your fingers to pop the screen out from the digitizer.
  4. HKC P776A Motherboard Replacement, Removing the Optical Cord from the Motherbaord: passo 4, immagine 1 di 1
    • With the plastic opening tool, lift the black latch up.
  5. HKC P776A Motherboard Replacement: passo 5, immagine 1 di 1
    • Pull the optical cord out from the motherboard.
  6. HKC P776A Motherboard Replacement, Separating the Screen and the Digitizer: passo 6, immagine 1 di 2 HKC P776A Motherboard Replacement, Separating the Screen and the Digitizer: passo 6, immagine 2 di 2
  7. HKC P776A Motherboard Replacement, Removing the Cable from the Motherboard: passo 7, immagine 1 di 2 HKC P776A Motherboard Replacement, Removing the Cable from the Motherboard: passo 7, immagine 2 di 2
    • Use the tip of the spudger to release the latches on the motherboard.
  8. HKC P776A Motherboard Replacement: passo 8, immagine 1 di 1
    • Remove the cable from the motherboard.
  9. HKC P776A Motherboard Replacement, Removing the Cable from the Moatherboard: passo 9, immagine 1 di 2 HKC P776A Motherboard Replacement, Removing the Cable from the Moatherboard: passo 9, immagine 2 di 2
  10. HKC P776A Motherboard Replacement: passo 10, immagine 1 di 2 HKC P776A Motherboard Replacement: passo 10, immagine 2 di 2
    • Remove the camera from the device.
  11. HKC P776A Motherboard Replacement, Wifi Antenna: passo 11, immagine 1 di 2 HKC P776A Motherboard Replacement, Wifi Antenna: passo 11, immagine 2 di 2
    • Peel off the tape that is attaching the wifi antenna to the case.
  12. HKC P776A Motherboard Replacement: passo 12, immagine 1 di 1
    • Using the soldering iron, heat up the solder that is attaching the antenna to the motheboard.
    • The heat from the soldering iron may cause personal injury or damage the internal components of the tablet.
  13. HKC P776A Motherboard Replacement: passo 13, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Desoldering Pump
    $3.99
    Compra
    • Suck up the leftover solder using the desoldering pump.
    • Remove the wifi antenna from the motherboard.
  14. HKC P776A Motherboard Replacement, Battery: passo 14, immagine 1 di 1
    • Insert the plastic opening tool between the battery and case.
    • Apply leverage to break the glue that is attaching the battery to the case.
  15. HKC P776A Motherboard Replacement: passo 15, immagine 1 di 1
    • Continue breaking the glue along the perimeter of the battery until the battery can be removed.
    • Breaking all the glue between the battery and case may take a long time.
  16. HKC P776A Motherboard Replacement: passo 16, immagine 1 di 2 HKC P776A Motherboard Replacement: passo 16, immagine 2 di 2
    • Using the soldering iron, heat up the solder that is attaching the battery to the motheboard.
  17. HKC P776A Motherboard Replacement: passo 17, immagine 1 di 1
    • Remove the battery from the motherboard.
  18. HKC P776A Motherboard Replacement, Motherboard: passo 18, immagine 1 di 3 HKC P776A Motherboard Replacement, Motherboard: passo 18, immagine 2 di 3 HKC P776A Motherboard Replacement, Motherboard: passo 18, immagine 3 di 3
    • Using the screwdriver, remove the four 4mm by 1.5mm screws that are attaching the motherboard to the case.
  19. HKC P776A Motherboard Replacement: passo 19, immagine 1 di 2 HKC P776A Motherboard Replacement: passo 19, immagine 2 di 2
    • Remove the black material that is covering the speaker.
  20. HKC P776A Motherboard Replacement: passo 20, immagine 1 di 1
    • Insert the spudger into the speaker slot on the back of the case.
  21. HKC P776A Motherboard Replacement: passo 21, immagine 1 di 1
    • Push the speaker out of the case with the spudger.
  22. HKC P776A Motherboard Replacement: passo 22, immagine 1 di 1
    • Remove the motherboard from the case.
Conclusione
Ryan Gornati
Membro da: 01/22/15
409 Reputazione
4 Guide realizzate
USF Tampa, Team 7-6, Remmell Winter 2015 Membro di USF Tampa, Team 7-6, Remmell Winter 2015
USFT-REMMELL-W15S7G6
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 173
