Salta al contenuto principale
HKC P776A Digitizer Replacement
Cosa ti serve
  1. HKC P776A Digitizer Replacement, Separating Digitizer and Case: passo 1, immagine 1 di 1
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Digitizer Replacement: passo 2, immagine 1 di 2 HKC P776A Digitizer Replacement: passo 2, immagine 2 di 2
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Digitizer Replacement, Separating the Screen and the Digitizer: passo 3, immagine 1 di 2 HKC P776A Digitizer Replacement, Separating the Screen and the Digitizer: passo 3, immagine 2 di 2
    • Use your fingers to pop the screen out from the digitizer.
  4. HKC P776A Digitizer Replacement, Removing the Cable from the Motherboard: passo 4, immagine 1 di 2 HKC P776A Digitizer Replacement, Removing the Cable from the Motherboard: passo 4, immagine 2 di 2
    • Use the tip of the spudger to release the latches on the motherboard.
  5. HKC P776A Digitizer Replacement: passo 5, immagine 1 di 1
    • Remove the cable from the motherboard.
Conclusione
USF Tampa, Team 7-6, Remmell Winter 2015 Membro di USF Tampa, Team 7-6, Remmell Winter 2015
USFT-REMMELL-W15S7G6
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 138
