Salta al contenuto principale
HKC P776A Battery Replacement
Cosa ti serve
  1. HKC P776A Battery Replacement, Separating Digitizer and Case: passo 1, immagine 1 di 1
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Battery Replacement: passo 2, immagine 1 di 2 HKC P776A Battery Replacement: passo 2, immagine 2 di 2
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Insert the plastic opening tool between the battery and case.
    • Apply leverage to break the glue that is attaching the battery to the case.
  4. HKC P776A Battery Replacement: passo 4, immagine 1 di 1
    • Continue breaking the glue along the perimeter of the battery until the battery can be removed.
    • Breaking all the glue between the battery and case may take a long time.
  5. HKC P776A Battery Replacement: passo 5, immagine 1 di 2 HKC P776A Battery Replacement: passo 5, immagine 2 di 2
    • Using the soldering iron, heat up the solder that is attaching the battery to the motheboard.
    • The heat from the soldering iron may cause personal injury or damage the internal components of the tablet.
  6. HKC P776A Battery Replacement: passo 6, immagine 1 di 1
    • Suck up the leftover solder using the desoldering pump.
    • Remove the battery from the motherboard.
Conclusione
Ryan Gornati
Membro da: 01/22/15
409 Reputazione
4 Guide realizzate
USF Tampa, Team 7-6, Remmell Winter 2015 Membro di USF Tampa, Team 7-6, Remmell Winter 2015
USFT-REMMELL-W15S7G6
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 644
