Salta al contenuto principale
HKC P771A Digitizer Replacement
Cosa ti serve
  1. HKC P771A Digitizer Replacement, Digitizer: passo 1, immagine 1 di 2 HKC P771A Digitizer Replacement, Digitizer: passo 1, immagine 2 di 2
    • Remove back of tablet using the plastic opening tool
    • Slide the opening tool between the back of the tablet and the digitizer
    • Lift along the edges until the back of the tablet and the digitizer are separated
  2. HKC P771A Digitizer Replacement: passo 2, immagine 1 di 2 HKC P771A Digitizer Replacement: passo 2, immagine 2 di 2
    • Remove 4 screws located on the red motherboard
    • The red motherboard will be loose, but does not need to come completely unattached
  3. HKC P771A Digitizer Replacement: passo 3, immagine 1 di 1
    • Remove 7 screws located around the edges of the tablet
    • 5 screws are visible around the edges of the device and 2 screws are located underneath the red motherboard
  4. HKC P771A Digitizer Replacement: passo 4, immagine 1 di 1
    • Lift digitizer from the screen
    • After removing all of the screws, the screen should easily separate from the digitizer
  5. HKC P771A Digitizer Replacement: passo 5, immagine 1 di 1
    • Now you can replace the old digitizer with a new one
Conclusione
Sara Hill
Membro da: 09/30/15
101 Reputazione
2 Guide realizzate
Ohio State, Team 2-3, Garvin Fall 2015 Membro di Ohio State, Team 2-3, Garvin Fall 2015
OSU-GARVIN-F15S2G3
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 252
