Salta al contenuto principale
HASEE Z6-SL7D1 RAM Replacement
Cosa ti serve
  1. HASEE Z6-SL7D1 RAM Replacement, RAM: passo 1, immagine 1 di 2 HASEE Z6-SL7D1 RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Flip your laptop over so the bottom is facing up and set it on a flat surface.
    • Use a Phillips #0 screwdriver to remove the two 6 mm screws that secure the battery.
  2. HASEE Z6-SL7D1 RAM Replacement: passo 2, immagine 1 di 2 HASEE Z6-SL7D1 RAM Replacement: passo 2, immagine 2 di 2
    • Gently lift the battery from the laptop.
  3. HASEE Z6-SL7D1 RAM Replacement: passo 3, immagine 1 di 2 HASEE Z6-SL7D1 RAM Replacement: passo 3, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove fourteen 6 mm screws from the back panel.
  4. HASEE Z6-SL7D1 RAM Replacement: passo 4, immagine 1 di 2 HASEE Z6-SL7D1 RAM Replacement: passo 4, immagine 2 di 2
    • If your laptop is equipped with an optical drive, carefully slide it out.
    • Alternatively, if the optical drive bay houses a hard drive tray, remove the tray by unscrewing any securing screws and gently pulling it out.
  5. HASEE Z6-SL7D1 RAM Replacement: passo 5, immagine 1 di 2 HASEE Z6-SL7D1 RAM Replacement: passo 5, immagine 2 di 2
    • Carefully slide a plastic spudger or opening tool along the edges of the back panel.
    • Gradually lift the panel away from the laptop chassis, ensuring not to force it and risking damage to internal components.
  6. HASEE Z6-SL7D1 RAM Replacement: passo 6, immagine 1 di 3 HASEE Z6-SL7D1 RAM Replacement: passo 6, immagine 2 di 3 HASEE Z6-SL7D1 RAM Replacement: passo 6, immagine 3 di 3
    • Use your fingers or a spudger to gently press the clips on the sides of the SO-DIMM slots outward to release the memory modules.
    • The RAM sticks will pop out at about a 45-degree angle.
    • Once the RAM sticks disengage, carefully slide them out of the slot at the same angle.
  7. HASEE Z6-SL7D1 RAM Replacement: passo 7, immagine 1 di 2 HASEE Z6-SL7D1 RAM Replacement: passo 7, immagine 2 di 2
    • When installing new memory sticks, align them with the SO-DIMM slots at the same angle and gently press them downward.
    • You will hear a click, indicating that it is securely in place.
  8. HASEE Z6-SL7D1 RAM Replacement: passo 8, immagine 1 di 2 HASEE Z6-SL7D1 RAM Replacement: passo 8, immagine 2 di 2
    • Replace the back case.
    • Insert the optical drive back into its designated slot.
    • Replace the battery.
    • Use a Phillips #0 screwdriver to secure the fourteen 6 mm screws on the back case.
    • Use a Phillips #0 screwdriver to replace the two 6 mm screws that secure the battery.
Conclusione
Altre 2 persone hanno completato questa guida.
Jiayi Liu
Membro da: 02/11/24
175 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 105
Tutti i Tempi: 1,533
