Salta al contenuto principale
Griffin iFM 4027 Left Side Panel Replacement
Cosa ti serve
  1. Griffin iFM 4027 Left Side Panel Replacement, Left Side Panel: passo 1, immagine 1 di 1
    • Lodge the tip of the plastic opening tool into the top arc where the side and main part of the device meet.
    • Push the plastic opening tool upward until the side panel detaches.
  2. Griffin iFM 4027 Left Side Panel Replacement: passo 2, immagine 1 di 3 Griffin iFM 4027 Left Side Panel Replacement: passo 2, immagine 2 di 3 Griffin iFM 4027 Left Side Panel Replacement: passo 2, immagine 3 di 3
    • Slide the plastic opening tool along the panel seam and push upward until the side panel detaches from the main device.
    • Turn over the detached side panel, so that the outer side is facing downward.
    • Then use your fingers to disassemble the panel button and set it off to the side.
Conclusione
Alexander
Membro da: 03/09/12
101 Reputazione
6 Guide realizzate
Clemson, Team 15-3, Benson Spring 2012 Membro di Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,126
