Introduzione
If the fork arm in The Buttonholer is not moving properly while being operated, chance are you need to replace the spring holding the arm.
Unscrew the screw located underneath fork arm using a Flathead screwdriver.
  • Unscrew the screw located underneath fork arm using a Flathead screwdriver.
Aggiungi Commento
Raise the fork arm so that it is parallel with the upper hook.
  • Raise the fork arm so that it is parallel with the upper hook.
  • Turn the lower hook towards you from the bottom, and remove.
Aggiungi Commento
  • Remove the old spring from the hook.
  • Add the new spring to the hook.
Aggiungi Commento
Conclusione
Michael Sykes
Membro da: 06/10/2014
552 Reputazione
5 Guide realizzate
USF Tampa, Team 3-6, Brown Fall 2014 Membro di USF Tampa, Team 3-6, Brown Fall 2014
USFT-BROWN-F14S3G6
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 72
