Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Depending on the size of the buttons that you will be using, you may need to replace the template already in The Buttonholer.
  1. Turn the adjusting knob to the right until the cloth clamp is extended as far as it can go. Turn the adjusting knob to the right until the cloth clamp is extended as far as it can go.
    • Turn the adjusting knob to the right until the cloth clamp is extended as far as it can go.
  2. Located on the bottom, pull the lip of the retainer plate away from The Buttonholer, and then open the plate. Located on the bottom, pull the lip of the retainer plate away from The Buttonholer, and then open the plate.
    • Located on the bottom, pull the lip of the retainer plate away from The Buttonholer, and then open the plate.
  3. Since the clamp is extended as far as it can go, the template should come out easily. Since the clamp is extended as far as it can go, the template should come out easily.
    • Since the clamp is extended as far as it can go, the template should come out easily.
  4. 4 additional templates are included with The Buttonholer. Each template creates a different size button hole. If you are unsure which template is right for your project, check the back of each template for the diameter of the holes that they make.
    • 4 additional templates are included with The Buttonholer. Each template creates a different size button hole.
    • If you are unsure which template is right for your project, check the back of each template for the diameter of the holes that they make.
  5. Place the template into The Buttonholer, and then close the retainer plate. Place the template into The Buttonholer, and then close the retainer plate.
    • Place the template into The Buttonholer, and then close the retainer plate.
Conclusione
Michael Sykes
Membro da: 06/10/2014
552 Reputazione
5 Guide realizzate
USF Tampa, Team 3-6, Brown Fall 2014 Membro di USF Tampa, Team 3-6, Brown Fall 2014
USFT-BROWN-F14S3G6
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 206
