Salta al contenuto principale
GravityLight Dial Replacement
Cosa ti serve
  1. GravityLight Dial Replacement, Removing the Front Panel: passo 1, immagine 1 di 2 GravityLight Dial Replacement, Removing the Front Panel: passo 1, immagine 2 di 2
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight Dial Replacement, Opening the Device Housing: passo 2, immagine 1 di 1
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight Dial Replacement, Isolating the Front Panel: passo 3, immagine 1 di 1
    • Take the thinner of the two parts, the front piece, and place it face down on a sturdy surface.
    • Ignore the back piece for now, but keep it in a safe place.
  4. GravityLight Dial Replacement, Popping the Dial out: passo 4, immagine 1 di 2 GravityLight Dial Replacement, Popping the Dial out: passo 4, immagine 2 di 2
    • Use two hands to push the dial tabs inward, towards the center of the dial.
    • Push the tabs downward and through to the other side of the casing.
    • Flip the front panel over.
  5. GravityLight Dial Replacement, Removing the Dial: passo 5, immagine 1 di 1
    • Fully remove the dial by pulling it out from the front.
Conclusione
Cal Poly, Team 12-2, Forte Fall 2014 Membro di Cal Poly, Team 12-2, Forte Fall 2014
CPSU-FORTE-F14S12G2
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 750
