Salta al contenuto principale
Graco Secure Coverage Parent Unit Battery Replacement
Cosa ti serve
  1. Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: passo 1, immagine 1 di 3 Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: passo 1, immagine 2 di 3 Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: passo 1, immagine 3 di 3
    • Using plastic opening tool, pry and remove the battery lid.
  2. Graco Secure Coverage Parent Unit Battery Replacement: passo 2, immagine 1 di 1
    • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
    • Make sure that you disconnect the battery's wire before you remove the battery.
Conclusione
Rogelio Morales
Membro da: 08/31/15
201 Reputazione
2 Guide realizzate
USF Tampa, Team 6-5, Remmell Fall 2015 Membro di USF Tampa, Team 6-5, Remmell Fall 2015
USFT-REMMELL-F15S6G5
4 Membri
8 Guide realizzate
Un commento
Would anyone happen to know the type of battery needed for the replacement on this baby monitor?
Shaun Barnes (WheelchairShaun) - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 778
