Salta al contenuto principale
Gotrax Hover board Charging port Replacement
Cosa ti serve
  1. Gotrax Hover board Charging port Replacement, Take apart: passo 1, immagine 1 di 1
    • First determine which side of the board has the power button and charging port on it. Then remove the bottom cover of the board by unscrewing the 10 screws on the power button side.
  2. Gotrax Hover board Charging port Replacement, Unplug: passo 2, immagine 1 di 1
    • Once you remove the cover unplug the charging port, power button, and LED light to make it easier to work on.
  3. Gotrax Hover board Charging port Replacement, Out with the old: passo 3, immagine 1 di 2 Gotrax Hover board Charging port Replacement, Out with the old: passo 3, immagine 2 di 2
    • Once the cover is completely detached unscrew the nut on the back of the charging port and power button that is securing it in its place. To remove the charging port and power button push them through front of the cover.
Conclusione
Haden Kuta
Membro da: 03/06/18
97 Reputazione
1 Guida realizzata
Vegas Room H9 Membro di Vegas Room H9
Community
13 Membri
19 Guide realizzate
1Commento della guida
Thanks For Sharing Amazing I Fix My Hoverboard
Motivational Story - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,718
