Salta al contenuto principale
Google Pixelbook Go Right Charging Port Replacement
Cosa ti serve
  1. Google Pixelbook Go Right Charging Port Replacement, Back Panel: passo 1, immagine 1 di 2 Google Pixelbook Go Right Charging Port Replacement, Back Panel: passo 1, immagine 2 di 2
    • Flip the device so that the back is facing up.
    • Peel the rubber stoppers off the top and bottom of the device.
  2. Google Pixelbook Go Right Charging Port Replacement: passo 2, immagine 1 di 2 Google Pixelbook Go Right Charging Port Replacement: passo 2, immagine 2 di 2
    • Remove ten 3 mm screws from around the edge of the back panel using a T5 Torx screwdriver.
  3. Google Pixelbook Go Right Charging Port Replacement: passo 3, immagine 1 di 3 Google Pixelbook Go Right Charging Port Replacement: passo 3, immagine 2 di 3 Google Pixelbook Go Right Charging Port Replacement: passo 3, immagine 3 di 3
    • Use an iFixit opening tool to pry up the back panel cover.
    • There is an orange ribbon cable that connects the cover to the base, so don't separate the two pieces completely.
    • Remove the single 2 mm screw using a Torx T3 screwdriver.
    • Disconnect the orange cable from the base of the device.
  4. Google Pixelbook Go Right Charging Port Replacement: passo 4, immagine 1 di 1
    • Insert wisdom here.
  5. Google Pixelbook Go Right Charging Port Replacement, Right Charging Port: passo 5, immagine 1 di 1
    • Remove the three pink screws from the right charging port using a T3 Torx screwdriver.
  6. Google Pixelbook Go Right Charging Port Replacement: passo 6, immagine 1 di 2 Google Pixelbook Go Right Charging Port Replacement: passo 6, immagine 2 di 2
    • Remove the right charging port by picking it up and lifting it from the computer.
Conclusione
Katie Brennan
Membro da: 03/01/23
85 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 184
