Salta al contenuto principale
Google Pixelbook Go Motherboard Replacement
Cosa ti serve
  1. Google Pixelbook Go Motherboard Replacement, Back Panel: passo 1, immagine 1 di 2 Google Pixelbook Go Motherboard Replacement, Back Panel: passo 1, immagine 2 di 2
    • Flip the device so that the back is facing up.
    • Peel the rubber stoppers off the top and bottom of the device.
  2. Google Pixelbook Go Motherboard Replacement: passo 2, immagine 1 di 2 Google Pixelbook Go Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove ten 3 mm screws from around the edge of the back panel using a T5 Torx screwdriver.
  3. Google Pixelbook Go Motherboard Replacement: passo 3, immagine 1 di 3 Google Pixelbook Go Motherboard Replacement: passo 3, immagine 2 di 3 Google Pixelbook Go Motherboard Replacement: passo 3, immagine 3 di 3
    • Use an iFixit opening tool to pry up the back panel cover.
    • There is an orange ribbon cable that connects the cover to the base, so don't separate the two pieces completely.
    • Remove the single 2 mm screw using a Torx T3 screwdriver.
    • Disconnect the orange cable from the base of the device.
  4. Google Pixelbook Go Motherboard Replacement: passo 4, immagine 1 di 1
    • Insert wisdom here.
  5. Google Pixelbook Go Motherboard Replacement, Motherboard: passo 5, immagine 1 di 1
    • Remove the seven 2.0 mm screws using a T3 Torx screwdriver.
  6. Google Pixelbook Go Motherboard Replacement: passo 6, immagine 1 di 3 Google Pixelbook Go Motherboard Replacement: passo 6, immagine 2 di 3 Google Pixelbook Go Motherboard Replacement: passo 6, immagine 3 di 3
    • If they didn't fall off already, remove the small, metal casings at the top of your Pixelbook Go.
    • Both pieces are different. Be mindful of which piece goes to which side, or refer back to this step.
  7. Google Pixelbook Go Motherboard Replacement: passo 7, immagine 1 di 3 Google Pixelbook Go Motherboard Replacement: passo 7, immagine 2 di 3 Google Pixelbook Go Motherboard Replacement: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect the blue and red wiring cable using the needle nose tweezers. Grab as close to the connection as you can, and tug in an upwards motion.
    • Do this to both sides.
  8. Google Pixelbook Go Motherboard Replacement: passo 8, immagine 1 di 3 Google Pixelbook Go Motherboard Replacement: passo 8, immagine 2 di 3 Google Pixelbook Go Motherboard Replacement: passo 8, immagine 3 di 3
    • Detach the left-hand side, wide ribbon by pulling away from the connection itself. Grab as close as you can to the connection using your spudger.
    • This part may require additional force, but be mindful not to snap it.
  9. Google Pixelbook Go Motherboard Replacement: passo 9, immagine 1 di 2 Google Pixelbook Go Motherboard Replacement: passo 9, immagine 2 di 2
    • Similarly, detach the right-hand side, flat ribbon by pulling away from the connection.
  10. Google Pixelbook Go Motherboard Replacement: passo 10, immagine 1 di 2 Google Pixelbook Go Motherboard Replacement: passo 10, immagine 2 di 2
    • Detach the thin, flat cable in the middle using your spudger or by gently pulling with your hand near the connection itself.
  11. Google Pixelbook Go Motherboard Replacement: passo 11, immagine 1 di 2 Google Pixelbook Go Motherboard Replacement: passo 11, immagine 2 di 2
    • Detach the wider, middle cable using the same steps as before. Pull away from the connection, grabbing as close to the connection as you can.
  12. Google Pixelbook Go Motherboard Replacement: passo 12, immagine 1 di 2 Google Pixelbook Go Motherboard Replacement: passo 12, immagine 2 di 2
    • Detach the small, copper colored cable from the motherboard. Since this cable is so small, it will require needle-nose tweezers.
  13. Google Pixelbook Go Motherboard Replacement: passo 13, immagine 1 di 3 Google Pixelbook Go Motherboard Replacement: passo 13, immagine 2 di 3 Google Pixelbook Go Motherboard Replacement: passo 13, immagine 3 di 3
    • By hand, disconnect the top two clips gently. Although you want to detach these clips from the motherboard, these clips will remain attached on the reverse end to the base.
  14. Google Pixelbook Go Motherboard Replacement: passo 14, immagine 1 di 3 Google Pixelbook Go Motherboard Replacement: passo 14, immagine 2 di 3 Google Pixelbook Go Motherboard Replacement: passo 14, immagine 3 di 3
    • Gently peel back the adhesive plastic covering towards the main body.
    • Avoid ripping the plastic covering as this is easy to do.
  15. Google Pixelbook Go Motherboard Replacement: passo 15, immagine 1 di 3 Google Pixelbook Go Motherboard Replacement: passo 15, immagine 2 di 3 Google Pixelbook Go Motherboard Replacement: passo 15, immagine 3 di 3
    • Detach the final two clips attached to the motherboard using the needle nose tweezers, located at the top left of the motherboard.
  16. Google Pixelbook Go Motherboard Replacement: passo 16, immagine 1 di 3 Google Pixelbook Go Motherboard Replacement: passo 16, immagine 2 di 3 Google Pixelbook Go Motherboard Replacement: passo 16, immagine 3 di 3
    • Remove the motherboard by gently lifting with your hands.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 23
Tutti i Tempi: 565
