Salta al contenuto principale
Introduzione
In this guide, you will learn how to remove the back panel of the Google Pixelbook in order to replace the battery. Since the back panel is heavily adhered to the batteries, it is near impossible to remove them without causing damage. We strongly recommend purchasing a whole new back panel/battery pack instead of attempting to separate them.
  1. Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook. Peel the linings off completely until the back of the Pixelbook looks bare. Peel the linings off completely until the back of the Pixelbook looks bare.
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
  2. Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver. Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
  3. Remove the seventeen 3.0mm T5 Torx screws from the bottom panel. Remove the seventeen 3.0mm T5 Torx screws from the bottom panel. Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
  4. Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers. Open the back panel completely and lay it flat so you see the whole inside of the computer. Open the back panel completely and lay it flat so you see the whole inside of the computer.
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
  5. Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise. Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
  6. Remove the small, black casing by using the spudger to lift it up from its place. Remove the small, black casing by using the spudger to lift it up from its place.
    • Remove the small, black casing by using the spudger to lift it up from its place.
  7. Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
Conclusione
Altre 10 persone hanno completato questa guida.
Megan Phillips
Membro da: 24/01/2018
400 Reputazione
1 Guida realizzata
Cal Poly, Team S18-G1, Livingston Winter 2018 Membro di Cal Poly, Team S18-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G1
4 Membri
6 Guide realizzate
Question; with the rubber pads removed from the bottom…is there adhesive and if so, what’s best used to replace those and make it look factory stock again?
Fabian Aldo Santiago - Replica
I just use Isopropyl alcohol to quickly and completely remove any adhesive residue and use an ample amount of JB Weld and Automotive Bondo to get the unit ready. Use a wet rag to remove any excess adhesive. Do not fo0rget to centrealize the Feline Eyelash right at the longest point of the night and invokie MARDUK!!! AAAHHRHRGH.
MyLil Hottie - Replica
So yeah basic Chemistry coupled with the ‘Dark Arts’ have created a sustainable situation.!
Where did you buy the back case replacement part?
cartercapelli - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 92
Ultimi 30 Giorni: 364
Tutti i Tempi: 6,785
