Introduzione
In this guide, you will learn how to remove the back panel of the Google Pixelbook in order to replace the battery. Since the back panel is heavily adhered to the batteries, it is near impossible to remove them without causing damage. We strongly recommend purchasing a whole new back panel/battery pack instead of attempting to separate them.
  1. Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
  2. Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
    • Remove the small, black casing by using the spudger to lift it up from its place.
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
Conclusione
Altre 4 persone hanno completato questa guida.
Megan Phillips
Membro da: 24/01/2018
244 Reputazione
1 Guida realizzata
Cal Poly, Team S18-G1, Livingston Winter 2018 Membro di Cal Poly, Team S18-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G1
4 Membri
6 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 79
Ultimi 30 Giorni: 377
Tutti i Tempi: 3,464
