Introduzione
This guide will instruct you how to replace the fingerprint scanner on your Google Pixel XL. Secured in place with only light adhesive, the scanner can be easily removed once accessed.
Cosa ti serve
Remove the two remaining 3mm T5 screws which secure the motherboard in place.
Peel the ribbon cable that connects to the fingerprint scanner off of the sticky pads on the inside of the phone.
Pull the glass panel out from the phone while routing the ribbon cable through the hole in the chassis.
Keep the glass panel and place the rest of the phone off to the side.
