Salta al contenuto principale
Google Pixel Slate Speaker Replacement
Cosa ti serve
  1. Google Pixel Slate Speaker Replacement, Screen: passo 1, immagine 1 di 3 Google Pixel Slate Speaker Replacement, Screen: passo 1, immagine 2 di 3 Google Pixel Slate Speaker Replacement, Screen: passo 1, immagine 3 di 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Speaker Replacement: passo 2, immagine 1 di 3 Google Pixel Slate Speaker Replacement: passo 2, immagine 2 di 3 Google Pixel Slate Speaker Replacement: passo 2, immagine 3 di 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Speaker Replacement, Speaker: passo 3, immagine 1 di 3 Google Pixel Slate Speaker Replacement, Speaker: passo 3, immagine 2 di 3 Google Pixel Slate Speaker Replacement, Speaker: passo 3, immagine 3 di 3
    • There are two speakers, one on each side of the Google Pixel Slate. This guide works for either one.
    • Use the T2 Torx screwdriver to remove the yellow 2mm screw from the thin metal plate.
    • Use the T3 Torx screwdriver to remove the pink 3mm screw from the thin metal plate.
    • Remove the thin metal plate from the device.
  4. Google Pixel Slate Speaker Replacement: passo 4, immagine 1 di 1
    • Use the T2 Torx screwdriver to remove the two black 2mm screws from the speaker.
  5. Google Pixel Slate Speaker Replacement: passo 5, immagine 1 di 2 Google Pixel Slate Speaker Replacement: passo 5, immagine 2 di 2
    • Use the Nylon-Tipped Tweezers to remove the black plug.
    • There is a red and a black wire connected to the black plug.
    • Pull the black plug in an upwards direction.
    • Be sure to gently remove plug, as using too much force can damage the connecting wires.
  6. Google Pixel Slate Speaker Replacement: passo 6, immagine 1 di 2 Google Pixel Slate Speaker Replacement: passo 6, immagine 2 di 2
    • Use the Nylon-Tipped Tweezers to disconnect the black tape-like plug connected to the speaker.
  7. Google Pixel Slate Speaker Replacement: passo 7, immagine 1 di 2 Google Pixel Slate Speaker Replacement: passo 7, immagine 2 di 2
    • Detach the speaker wire from the motherboard.
    • Remove the adhesive strips that hold down the speaker wire.
  8. Google Pixel Slate Speaker Replacement: passo 8, immagine 1 di 3 Google Pixel Slate Speaker Replacement: passo 8, immagine 2 di 3 Google Pixel Slate Speaker Replacement: passo 8, immagine 3 di 3
    • Use the T2 Torx screwdriver to remove the 2mm black screw from the brass plate.
    • Pull back the brass plate.
  9. Google Pixel Slate Speaker Replacement: passo 9, immagine 1 di 1
    • You can now remove the speaker from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team S2-G5, Maness Spring 2019 Membro di Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 806
