Salta al contenuto principale
Google Pixel Slate Rear-Facing Camera Replacement
Cosa ti serve
  1. Google Pixel Slate Rear-Facing Camera Replacement, Screen: passo 1, immagine 1 di 3 Google Pixel Slate Rear-Facing Camera Replacement, Screen: passo 1, immagine 2 di 3 Google Pixel Slate Rear-Facing Camera Replacement, Screen: passo 1, immagine 3 di 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Rear-Facing Camera Replacement: passo 2, immagine 1 di 3 Google Pixel Slate Rear-Facing Camera Replacement: passo 2, immagine 2 di 3 Google Pixel Slate Rear-Facing Camera Replacement: passo 2, immagine 3 di 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Rear-Facing Camera Replacement, Rear-Facing Camera: passo 3, immagine 1 di 3 Google Pixel Slate Rear-Facing Camera Replacement, Rear-Facing Camera: passo 3, immagine 2 di 3 Google Pixel Slate Rear-Facing Camera Replacement, Rear-Facing Camera: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use a T2 Torx screwdriver to remove the two black 2mm screws holding down the square plate.
    • Use the Nylon Tipped Tweezers to lift the metal plate.
  4. Google Pixel Slate Rear-Facing Camera Replacement: passo 4, immagine 1 di 3 Google Pixel Slate Rear-Facing Camera Replacement: passo 4, immagine 2 di 3 Google Pixel Slate Rear-Facing Camera Replacement: passo 4, immagine 3 di 3
    • Use a T3 Torx screwdriver to remove the two yellow and grey 3mm screws from the L-shaped plate.
    • Use the Nylon Tipped Tweezers to lift the plate from the device.
  5. Google Pixel Slate Rear-Facing Camera Replacement: passo 5, immagine 1 di 2 Google Pixel Slate Rear-Facing Camera Replacement: passo 5, immagine 2 di 2
    • Gently pull upwards to remove the camera.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S2-G5, Maness Spring 2019 Membro di Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 707
