Salta al contenuto principale
Google Pixel Slate Front-Facing Camera Replacement
Cosa ti serve
  1. Google Pixel Slate Front-Facing Camera Replacement, Screen: passo 1, immagine 1 di 3 Google Pixel Slate Front-Facing Camera Replacement, Screen: passo 1, immagine 2 di 3 Google Pixel Slate Front-Facing Camera Replacement, Screen: passo 1, immagine 3 di 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Front-Facing Camera Replacement: passo 2, immagine 1 di 3 Google Pixel Slate Front-Facing Camera Replacement: passo 2, immagine 2 di 3 Google Pixel Slate Front-Facing Camera Replacement: passo 2, immagine 3 di 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: passo 3, immagine 1 di 3 Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: passo 3, immagine 2 di 3 Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: passo 3, immagine 3 di 3
    • Once removed, place the screen face down.
    • Peel back the black, adhesive strip covering the front camera so that the silver plate is exposed.
  4. Google Pixel Slate Front-Facing Camera Replacement: passo 4, immagine 1 di 3 Google Pixel Slate Front-Facing Camera Replacement: passo 4, immagine 2 di 3 Google Pixel Slate Front-Facing Camera Replacement: passo 4, immagine 3 di 3
    • Hold back the adhesive tape to expose the two black 2mm screws that are holding down the cover plate.
    • Use the T2 Torx screwdriver to remove the two 2mm screws.
  5. Google Pixel Slate Front-Facing Camera Replacement: passo 5, immagine 1 di 2 Google Pixel Slate Front-Facing Camera Replacement: passo 5, immagine 2 di 2
    • Once the two 2mm screws are removed, lift and remove the cover plate.
  6. Google Pixel Slate Front-Facing Camera Replacement: passo 6, immagine 1 di 2 Google Pixel Slate Front-Facing Camera Replacement: passo 6, immagine 2 di 2
    • Pull upwards on the flat wire to remove the front-facing camera from the device.
    • The camera may be secured to the screen body with adhesive tape. Apply gentle force to remove the camera by removing the tape.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S2-G5, Maness Spring 2019 Membro di Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 16
Tutti i Tempi: 632
