Salta al contenuto principale
Google Pixel C Keyboard Replacement
Cosa ti serve
  1. Google Pixel C Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Heat the black plastic strip on the front lower edge of the keyboard with an iOpener to weaken the adhesive holding it down.
    • When reattaching the plastic strip, apply adhesive to ensure that the strip will stay securely in place.
  2. Google Pixel C Keyboard Replacement: passo 2, immagine 1 di 2 Google Pixel C Keyboard Replacement: passo 2, immagine 2 di 2
    • Use a medium plastic opening tool to lift the black plastic strip from the lower edge of the keyboard.
  3. Google Pixel C Keyboard Replacement: passo 3, immagine 1 di 2 Google Pixel C Keyboard Replacement: passo 3, immagine 2 di 2
    • Locate the four 3.1mm Phillips #000 screws that hold the keyboard to the back plate.
    • Using the Phillips #000 Screwdriver, remove the screws from the keyboard.
    • The screws are reverse threaded, so turn them clockwise to remove them.
  4. Google Pixel C Keyboard Replacement: passo 4, immagine 1 di 1
    • Orient the keyboard so that the side with the keys is facedown on the table.
    • Use either an iFixit iOpener OR a heat gun to melt the adhesive that holds the top half of the keyboard to the bottom.
    • When using a heat gun for removal, only heat the backside of the keyboard to avoid warping the keys.
  5. Google Pixel C Keyboard Replacement: passo 5, immagine 1 di 3 Google Pixel C Keyboard Replacement: passo 5, immagine 2 di 3 Google Pixel C Keyboard Replacement: passo 5, immagine 3 di 3
    • Using a plastic or nylon spudger, pry the two halves of the keyboard apart.
    • If the plastic spudger doesn’t work, it is okay to use a metal spudger, but take care not to scratch or damage the device.
    • Be mindful of the amount of force applied to avoid snapping the keyboard.
    • It will be necessary to use adhesive to ensure that the keyboard is securely in place during reassembly.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S21-G4, Livingston Spring 2017 Membro di Cal Poly, Team S21-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G4
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,943
