Salta al contenuto principale
Google Pixel C Headphone Jack Replacement
Cosa ti serve
  1. Google Pixel C Headphone Jack Replacement, Screen: passo 1, immagine 1 di 1
    • Ensure that the device is completely powered down before beginning to take it apart
    • Use a heat gun to melt the adhesive that holds the screen to the device
    • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
    • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
  2. Google Pixel C Headphone Jack Replacement: passo 2, immagine 1 di 2 Google Pixel C Headphone Jack Replacement: passo 2, immagine 2 di 2
    • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
    • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
    • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
    • Reattaching the screen will require adhesive to ensure that it stays in place.
  3. Google Pixel C Headphone Jack Replacement: passo 3, immagine 1 di 2 Google Pixel C Headphone Jack Replacement: passo 3, immagine 2 di 2
    • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
  4. Google Pixel C Headphone Jack Replacement: passo 4, immagine 1 di 2 Google Pixel C Headphone Jack Replacement: passo 4, immagine 2 di 2
    • Follow the same removal procedure to detach the wide gold cable.
    • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
    • This device is missing a battery, so the device that you are working on may appear slightly different inside.
  5. Google Pixel C Headphone Jack Replacement, Headphone Jack: passo 5, immagine 1 di 1
    • Orient the device so that the headphone jack is in the bottom right corner.
  6. Google Pixel C Headphone Jack Replacement: passo 6, immagine 1 di 2 Google Pixel C Headphone Jack Replacement: passo 6, immagine 2 di 2
    • Remove the two 3.5mm Phillips #000 screws.
  7. Google Pixel C Headphone Jack Replacement: passo 7, immagine 1 di 1
    • Locate and remove the two 2.5mm Phillips #000 screws on either side of the wire coil.
  8. Google Pixel C Headphone Jack Replacement: passo 8, immagine 1 di 2 Google Pixel C Headphone Jack Replacement: passo 8, immagine 2 di 2
    • Detach the red and black cable using a narrow spudger.
  9. Google Pixel C Headphone Jack Replacement: passo 9, immagine 1 di 2 Google Pixel C Headphone Jack Replacement: passo 9, immagine 2 di 2
    • Detach the cable connecting to the headphone jack.
  10. Google Pixel C Headphone Jack Replacement: passo 10, immagine 1 di 2 Google Pixel C Headphone Jack Replacement: passo 10, immagine 2 di 2
    • Lift the headphone jack, coiled wire, and cable, peeling the adhesive back.
    • Reassembly will require adhesive to ensure that the components are secured to the device.
Conclusione
Cal Poly, Team S21-G4, Livingston Spring 2017 Membro di Cal Poly, Team S21-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G4
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 11
Tutti i Tempi: 961
