Introduzione
Use this guide to remove and replace the headphone jack in a Google Pixel 5a. The headphone jack may get water damaged or bent and need to be replaced after extended use. This replacement of the headphone jack is a moderate-level job that does not require prior experience. If you plan on reusing your phone screen, take special care in the removal of the screen so as to not damage it.
Before starting the guide turn off your device.
Cosa ti serve
Shut down the device before starting screen removal.
Insert a paper clip or SIM card removal tool into the SIM card tray hole.
Apply a small amount of pressure until the tray pops out.
Slide the SIM card tray out of your Google Pixel 5a.
Place an opening tool under the headphone jack connector and pry upward.
