Salta al contenuto principale
Google Pixel 3 XL Rear-Facing Camera Replacement
Cosa ti serve
  1. Google Pixel 3 XL Rear-Facing Camera Replacement, Heat the edge of the back cover: passo 1, immagine 1 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Heat the edge of the back cover: passo 1, immagine 2 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Heat the edge of the back cover: passo 1, immagine 3 di 3
    • Heat an iOpener and apply it to the right edge of the back cover for a minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • While you wait, note the following areas on the back cover:
    • Strong adhesive—there are large patches of adhesive near the bottom of the phone.
    • Fingerprint sensor cable—be careful not to slice through the cable as you pry
  2. Google Pixel 3 XL Rear-Facing Camera Replacement, Create a gap under the back cover: passo 2, immagine 1 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Create a gap under the back cover: passo 2, immagine 2 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Create a gap under the back cover: passo 2, immagine 3 di 3
    • Apply a suction cup to the heated edge of the back cover, as close to the edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  3. Google Pixel 3 XL Rear-Facing Camera Replacement, Loosen the right edge adhesives: passo 3, immagine 1 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Loosen the right edge adhesives: passo 3, immagine 2 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Loosen the right edge adhesives: passo 3, immagine 3 di 3
    • Slide the opening pick along the right edge to slice through the adhesive.
    • The adhesive gums up and becomes hard to slice once it cools. If that happens, re-apply heat to the edge to make slicing easier.
    • Once you have sliced through the edge, leave an opening pick in the seam to prevent the adhesive from re-sealing.
  4. Google Pixel 3 XL Rear-Facing Camera Replacement, Heat the bottom edge of the back cover: passo 4, immagine 1 di 1
    • Apply a heated iOpener to the bottom of the back cover for a minute.
  5. Google Pixel 3 XL Rear-Facing Camera Replacement, Slice through the bottom adhesives: passo 5, immagine 1 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Slice through the bottom adhesives: passo 5, immagine 2 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Slice through the bottom adhesives: passo 5, immagine 3 di 3
    • Use an opening pick to slice around the bottom right corner and continue along the bottom edge of the phone.
    • Work slowly as you slice around the corner to prevent the panel from cracking. If the slicing becomes hard, re-apply heat.
    • Leave a pick in the edge to prevent the adhesive from re-sealing.
  6. Google Pixel 3 XL Rear-Facing Camera Replacement, Slice through the remaining edges: passo 6, immagine 1 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Slice through the remaining edges: passo 6, immagine 2 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Slice through the remaining edges: passo 6, immagine 3 di 3
    • Continue heating and slicing the remaining edges of the phone.
    • Be careful as you slice along the left edge of the phone. If your pick feels like it's stuck near the top, you may have snagged the fingerprint sensor. Retract the pick out of the seam slightly and try again.
    • Be sure to cut through the thick portions of adhesive near the bottom and right edge of the phone.
  7. Google Pixel 3 XL Rear-Facing Camera Replacement, Slice through the leftover adhesive: passo 7, immagine 1 di 1
    • Gently pry up the right edge of the back cover.
    • Use an opening pick to slice through any remaining adhesive along the edges.
  8. Google Pixel 3 XL Rear-Facing Camera Replacement, Swing open the back cover: passo 8, immagine 1 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Swing open the back cover: passo 8, immagine 2 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Swing open the back cover: passo 8, immagine 3 di 3
    • Swing the right edge of the back cover upwards and rest the flipped panel along the left side of the phone.
    • Be sure to maintain slack on the fingerprint sensor cable and prevent it from being pinched.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • During reassembly, follow this guide to install custom-cut adhesives for your back cover.
    • If you replaced the fingerprint sensor, you'll need to use this software tool to make the phone recognize the new sensor.
  9. Google Pixel 3 XL Rear-Facing Camera Replacement, Remove the fingerprint sensor tape: passo 9, immagine 1 di 1
    • User tweezers to carefully peel up the yellow tape over the fingerprint sensor connector.
  10. Google Pixel 3 XL Rear-Facing Camera Replacement, Disconnect the fingerprint sensor: passo 10, immagine 1 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Disconnect the fingerprint sensor: passo 10, immagine 2 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Disconnect the fingerprint sensor: passo 10, immagine 3 di 3
    • Use the point of a spudger to carefully flip up the black lock bar on the fingerprint sensor's ZIF socket.
    • Grasp the cable's tab with your fingers or tweezers and gently walk the flex cable out of the socket.
    • To prevent shorting, be careful not to touch the metal contacts on the flex cable with your tweezers.
  11. Google Pixel 3 XL Rear-Facing Camera Replacement, Remove the back cover: passo 11, immagine 1 di 1
    • Remove the back cover.
    • Follow this guide to correctly apply new back cover adhesive.
  12. Google Pixel 3 XL Rear-Facing Camera Replacement, Remove the metal cover bracket screws: passo 12, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    Compra
    • Remove the following four T3 screws securing the metal cover bracket:
    • Three 4 mm long screws
    • One 3 mm long screw
  13. Google Pixel 3 XL Rear-Facing Camera Replacement, Remove the metal cover bracket: passo 13, immagine 1 di 2 Google Pixel 3 XL Rear-Facing Camera Replacement, Remove the metal cover bracket: passo 13, immagine 2 di 2
    • Insert the flat end of a spudger underneath the top right edge of the metal bracket and pry up to loosen it.
    • Remove the metal cover bracket.
  14. Google Pixel 3 XL Rear-Facing Camera Replacement, Disconnect the battery: passo 14, immagine 1 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Disconnect the battery: passo 14, immagine 2 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Disconnect the battery: passo 14, immagine 3 di 3
    • Use the point of a spudger to pry up and disconnect the battery connector from its socket.
    • Do not use metal tools to to disconnect the battery, or you will risk shorting the battery.
    • Bend the battery cable such that the connector will not accidentally touch the socket.
  15. Google Pixel 3 XL Rear-Facing Camera Replacement, Remove the motherboard shield screws: passo 15, immagine 1 di 1
    • Remove the five T3 screws securing the motherboard shield:
    • Two 3 mm long screws
  16. Google Pixel 3 XL Rear-Facing Camera Replacement, Remove the motherboard shield: passo 16, immagine 1 di 1
    • Remove the motherboard shield.
  17. Google Pixel 3 XL Rear-Facing Camera Replacement, Remove the front camera bracket: passo 17, immagine 1 di 1
    • Remove the three 3 mm long T3 screws securing the front camera bracket.
  18. Google Pixel 3 XL Rear-Facing Camera Replacement, Remove the front camera bracket: passo 18, immagine 1 di 1
    • Remove the front camera bracket.
  19. Google Pixel 3 XL Rear-Facing Camera Replacement, Determine which camera to remove: passo 19, immagine 1 di 1
    • Determine which camera you wish to replace:
    • Normal angle camera
    • Wide angle camera
  20. Google Pixel 3 XL Rear-Facing Camera Replacement, Disconnect the front camera(s): passo 20, immagine 1 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Disconnect the front camera(s): passo 20, immagine 2 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Disconnect the front camera(s): passo 20, immagine 3 di 3
    • Use the point of a spudger to carefully pry up and disconnect the cameras from their motherboard sockets.
    • Be very careful not to dislodge the small surface-mounted components surrounding the sockets.
  21. Google Pixel 3 XL Rear-Facing Camera Replacement, Loosen the front camera(s): passo 21, immagine 1 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Loosen the front camera(s): passo 21, immagine 2 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Loosen the front camera(s): passo 21, immagine 3 di 3
    • The cameras are lightly adhered in place.
    • Use the flat end of a spudger to pry up and loosen the camera modules from their recess.
  22. Google Pixel 3 XL Rear-Facing Camera Replacement, Remove the front-facing camera(s): passo 22, immagine 1 di 1
    • Remove the front-facing cameras.
  23. Google Pixel 3 XL Rear-Facing Camera Replacement, Remove one loudspeaker screw: passo 23, immagine 1 di 1
    • Remove the 4 mm long T3 screw securing the top-right corner of the loudspeaker.
    • Removing this screw will give you slightly more wiggle room when removing the motherboard.
  24. Google Pixel 3 XL Rear-Facing Camera Replacement, Remove the button array connector bracket: passo 24, immagine 1 di 1
    • Remove the two 3 mm long T3 screws securing the button array connector bracket.
  25. Google Pixel 3 XL Rear-Facing Camera Replacement: passo 25, immagine 1 di 1
    • Remove the button array connector bracket.
  26. Google Pixel 3 XL Rear-Facing Camera Replacement, Disconnect the earpiece speaker: passo 26, immagine 1 di 2 Google Pixel 3 XL Rear-Facing Camera Replacement, Disconnect the earpiece speaker: passo 26, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the earpiece connector from its motherboard socket.
    • Carefully remove the connector pad surrounding the earpiece socket.
  27. Google Pixel 3 XL Rear-Facing Camera Replacement, Disconnect the motherboard connectors: passo 27, immagine 1 di 1
    • Use the point of a spudger to pry up and disconnect the following:
    • Microphone connector
    • Button array connector
    • Earpiece connector (should already be disconnected)
  28. Google Pixel 3 XL Rear-Facing Camera Replacement: passo 28, immagine 1 di 2 Google Pixel 3 XL Rear-Facing Camera Replacement: passo 28, immagine 2 di 2
    • Charging coil connector
    • Left squeeze sensor connector
    • Display connector
    • Right squeeze sensor connector
    • Loudspeaker connector
    • USB-C port connector
  29. Google Pixel 3 XL Rear-Facing Camera Replacement, Remove the motherboard screws: passo 29, immagine 1 di 1
    • Remove the two 3 mm long T3 screws securing the motherboard.
  30. Google Pixel 3 XL Rear-Facing Camera Replacement, Loosen the motherboard: passo 30, immagine 1 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Loosen the motherboard: passo 30, immagine 2 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement, Loosen the motherboard: passo 30, immagine 3 di 3
    • Insert the point of a spudger underneath the motherboard, near the rear-facing camera module.
    • Pry up gently to loosen the motherboard from its recess.
    • If the motherboard is not budging, make sure you have disconnected all the connectors.
    • The motherboard has to squeeze past the earpiece speaker cable. If too much pressure is put on the earpiece cable, the earpiece speaker will pop open. You can prevent this by pressing on the earpiece module with a finger while you maneuver the motherboard out.
    • If the earpiece speaker pops open (as shown in the third photo of this step), carefully align and press the module back in place.
  31. Google Pixel 3 XL Rear-Facing Camera Replacement: passo 31, immagine 1 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement: passo 31, immagine 2 di 3 Google Pixel 3 XL Rear-Facing Camera Replacement: passo 31, immagine 3 di 3
    • Don't attempt to remove the motherboard from the phone. It's still attached to the phone.
    • While you perform this step, take care to keep slack on the antenna cables attached to the bottom leg of the motherboard.
    • Lift the top half of the motherboard slightly to clear the board from its recess.
    • Twist the left edge of the board over and out of the phone and rest the board on the right edge of the phone.
  32. Google Pixel 3 XL Rear-Facing Camera Replacement, Disconnect the rear-facing camera: passo 32, immagine 1 di 2 Google Pixel 3 XL Rear-Facing Camera Replacement, Disconnect the rear-facing camera: passo 32, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the rear-facing camera from its motherboard socket.
  33. Google Pixel 3 XL Rear-Facing Camera Replacement, Remove the rear-facing camera: passo 33, immagine 1 di 1
    • Remove the rear-facing camera.
    • If your replacement camera module has a plastic spacer, be sure to remove it before you install the module.
    • Make sure the lens surface is smudge and dust free before you install the camera assembly.
Conclusione
Altre 3 persone hanno completato questa guida.
Arthur Shi
Membro da: 01/03/18
252.690 Reputazione
526 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 3,039
