Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Follow this guide to replace the charging assembly for the Pixel 3. The charging assembly contains the USB-C port as well as some antenna connectors, and is layered underneath the loudspeaker. This requires removing the loudspeaker first, which will compromise the loudspeaker’s ingress gasket.
  1. Heat an iOpener and apply it to the bottom of the phone for one minute. When prying above the power button, be careful not to insert the pick too deeply, or you will damage the fingerprint sensor cable.
    • Heat an iOpener and apply it to the bottom of the phone for one minute.
    • When prying above the power button, be careful not to insert the pick too deeply, or you will damage the fingerprint sensor cable.
  2. Apply a suction cup to the heated bottom edge of the phone. If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Lift on the suction cup with strong, steady force to create a gap.
    • Apply a suction cup to the heated bottom edge of the phone.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere.
    • Lift on the suction cup with strong, steady force to create a gap.
    • Depending on how aged your phone is, this may take significant force. If you are having trouble, apply more heat and try again.
    • Insert an opening pick into the gap.
  3. Slice the adhesive along the bottom edge of the phone and around the right corner. Leave a pick in the bottom edge to prevent the adhesive from re-sealing. Leave a pick in the bottom edge to prevent the adhesive from re-sealing.
    • Slice the adhesive along the bottom edge of the phone and around the right corner.
    • Leave a pick in the bottom edge to prevent the adhesive from re-sealing.
  4. Heat the right edge with an iOpener and continue slicing the adhesive with an opening pick. The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing. The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Heat the right edge with an iOpener and continue slicing the adhesive with an opening pick.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
  5. Continue heating and slicing through the rest of the phone perimeter. Leave a pick in each edge to prevent the adhesive from resealing. When slicing above the power button, do not insert the pick more than halfway in to avoid damaging the fingerprint sensor cable. When slicing above the power button, do not insert the pick more than halfway in to avoid damaging the fingerprint sensor cable.
    • Continue heating and slicing through the rest of the phone perimeter. Leave a pick in each edge to prevent the adhesive from resealing.
    • When slicing above the power button, do not insert the pick more than halfway in to avoid damaging the fingerprint sensor cable.
  6. Once you have sliced around the perimeter of the phone, carefully lift the left edge of the back cover. Do not attempt to remove the back cover. It is still attached to the phone by the fingerprint sensor cable. Flip the back cover along its long axis and rest it so that the fingerprint sensor cable is not strained.
    • Once you have sliced around the perimeter of the phone, carefully lift the left edge of the back cover.
    • Do not attempt to remove the back cover. It is still attached to the phone by the fingerprint sensor cable.
    • Flip the back cover along its long axis and rest it so that the fingerprint sensor cable is not strained.
  7. Remove the two 4.1 mm long Phillips screws securing the fingerprint connector bracket.
    • Remove the two 4.1 mm long Phillips screws securing the fingerprint connector bracket.
    • During reassembly, be careful not to over-tighten these screws, or you may damage your display.
  8. Use the point of a spudger to slide the fingerprint connector bracket out from under the NFC coil. Remove the fingerprint connector bracket. Remove the fingerprint connector bracket.
    • Use the point of a spudger to slide the fingerprint connector bracket out from under the NFC coil.
    • Remove the fingerprint connector bracket.
  9. Use the point of a spudger to pry up and disconnect the fingerprint connector from its socket. When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Use the point of a spudger to pry up and disconnect the fingerprint connector from its socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  10. Remove the back cover. Before you install a replacement back cover, be sure to remove all adhesive residue from the phone frame. Use an opening tool to scrape and high concentration isopropyl alcohol to clean the surface. If you are re-using the back cover, be sure to clean off any adhesive, and apply new back cover adhesive.
    • Remove the back cover.
    • Before you install a replacement back cover, be sure to remove all adhesive residue from the phone frame. Use an opening tool to scrape and high concentration isopropyl alcohol to clean the surface.
    • If you are re-using the back cover, be sure to clean off any adhesive, and apply new back cover adhesive.
    • If you are installing a replacement back cover, be sure compare it with the original part. Transfer any remaining parts (such as the flash diffuser) over to your replacement part.
  11. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  12. Remove the five Phillips screws securing the wireless charging coil: Two 1.9 mm screws Two 4.2 mm screws
    • Remove the five Phillips screws securing the wireless charging coil:
    • Two 1.9 mm screws
    • Two 4.2 mm screws
    • One 4.3 mm screw
    • Remove the wireless charging coil.
  13. Use the point of a spudger to pry up and disconnect the battery connector from its socket near the right edge of the phone. Use the point of a spudger to pry up and disconnect the battery connector from its socket near the right edge of the phone.
    • Use the point of a spudger to pry up and disconnect the battery connector from its socket near the right edge of the phone.
  14. Use the point of a spudger to pry up and disconnect the loudspeaker connector from its motherboard socket near the right edge of the phone. Be careful not to puncture the battery with the spudger.
    • Use the point of a spudger to pry up and disconnect the loudspeaker connector from its motherboard socket near the right edge of the phone.
    • Be careful not to puncture the battery with the spudger.
  15. Remove the following four Phillips screws: One 1.9 mm screw One 4.3 mm screw
    • Remove the following four Phillips screws:
    • One 1.9 mm screw
    • One 4.3 mm screw
    • Two 4.3 mm screws with thinner shanks
    • Remove the tiny grounding clip from the left screw hole. Be careful not to lose it.
    • The grounding clip installs such that the contoured edge faces the left side of the phone.
    • Remove the small plastic insert from the right side of the USB-C port.
    • Be sure to reinstall this insert before you screw down the daughterboard.
  16. The loudspeaker is still held in place by a strong adhesive gasket. Before attempting to remove it, pry it up in a few different places to break the adhesive seal. Insert the point of a spudger under the bottom right corner of the loudspeaker.
    • The loudspeaker is still held in place by a strong adhesive gasket. Before attempting to remove it, pry it up in a few different places to break the adhesive seal.
    • Insert the point of a spudger under the bottom right corner of the loudspeaker.
    • Pry up to loosen the loudspeaker from the phone.
  17. Insert the point of a spudger under the top left corner of the loudspeaker. Be careful not to puncture the battery with the spudger.
    • Insert the point of a spudger under the top left corner of the loudspeaker.
    • Pry up to loosen the loudspeaker.
  18. Insert the flat end of the spudger under the top edge of the loudspeaker, towards the left edge. Pry up to loosen the loudspeaker.
    • Insert the flat end of the spudger under the top edge of the loudspeaker, towards the left edge.
  19. Remove the loudspeaker. Before you install a replacement loudspeaker, check the adhesive gasket.
    • Remove the loudspeaker.
    • Before you install a replacement loudspeaker, check the adhesive gasket.
    • If it is in good condition, you can re-use the gasket. Make sure that the gasket does not cover the exit hole.
    • If the gasket is pulled out of place, remove it and replace the adhesive with a pre-cut strip or Tesa tape.
  20. Use the point of a spudger to pry up and disconnect the blue antenna cable from its socket on the charging assembly. Use the point of a spudger to pry up and disconnect the blue antenna cable from its socket on the charging assembly.
    • Use the point of a spudger to pry up and disconnect the blue antenna cable from its socket on the charging assembly.
  21. Use the point of a spudger to carefully pry up and release the blue antenna cable from its grounding clip. The cable is fragile and prone to breaking. If it feels like the wire is firmly clamped in place, use the point of a spudger to push the clip open slightly, then try again.
    • Use the point of a spudger to carefully pry up and release the blue antenna cable from its grounding clip.
    • The cable is fragile and prone to breaking. If it feels like the wire is firmly clamped in place, use the point of a spudger to push the clip open slightly, then try again.
  22. Use the point of a spudger to pry up and disconnect the black antenna cable from its socket near the USB-C port. Use the point of a spudger to pry up and disconnect the black antenna cable from its socket near the USB-C port.
    • Use the point of a spudger to pry up and disconnect the black antenna cable from its socket near the USB-C port.
  23. Carefully de-route both antenna cables and move them away from the charging assembly.
    • Carefully de-route both antenna cables and move them away from the charging assembly.
  24. Use the point of a spudger to pry up and disconnect the charging assembly's connector from its motherboard socket, near the right edge of the phone. Carefully peel the flex cable from the top of the SIM card reader. Carefully peel the flex cable from the top of the SIM card reader.
    • Use the point of a spudger to pry up and disconnect the charging assembly's connector from its motherboard socket, near the right edge of the phone.
    • Carefully peel the flex cable from the top of the SIM card reader.
  25. Remove the two 1.9 mm Phillips screws securing the charging assembly to the bottom edge of the phone.
    • Remove the two 1.9 mm Phillips screws securing the charging assembly to the bottom edge of the phone.
  26. Apply a heated iOpener to the bottom edge of the phone for a minute to loosen the adhesive holding the charging assembly in place.
    • Apply a heated iOpener to the bottom edge of the phone for a minute to loosen the adhesive holding the charging assembly in place.
  27. Insert an opening pick underneath the charging assembly's flex cable. Slide the opening pick below the charging assembly to loosen it from the phone. Slide the opening pick below the charging assembly to loosen it from the phone.
    • Insert an opening pick underneath the charging assembly's flex cable.
    • Slide the opening pick below the charging assembly to loosen it from the phone.
  28. Remove the charging assembly.
    • Remove the charging assembly.
  29. When you are installing a replacement assembly: Be sure to remove all plastic liners from the assembly to expose the adhesive. Line up the assembly's bottom left corner into place.
    • When you are installing a replacement assembly:
    • Be sure to remove all plastic liners from the assembly to expose the adhesive.
    • Line up the assembly's bottom left corner into place.
    • Carefully lay the rest of the assembly in place, making sure that the USB-C port is correctly seated in its respective cutout.
    • Use your fingers to press the assembly onto the frame.
Conclusione
Repair didn’t go as planned? Check out our Google Pixel 3 Answers community for troubleshooting help.
Altre 9 persone hanno completato questa guida.
Arthur Shi
Membro da: 03/01/2018
128.468 Reputazione
371 Guide realizzate
iFixit Membro di iFixit
Community
128 Membri
13.052 Guide realizzate
is the adhesive for the back of the phone reusable, or do I need to buy a replacement adhesive for reassembly?
Campbell Wright - Replica
It depends on the age of your phone it seems - the older the phone, the less resuseable the existing adhesive. I used gasket maker to reseal my phone, in part because I did not want to heat my new battery up when trying to reseal the back cover. I would advise getting some additional adhesive if you want a water-tight assembly.
Andrew Williams -
Best to order a new back phone lid, as my back lid shattered when trying to prise it off, despite repeated heating to uncomfortably hot. Also, if you’re replacing the charging logic board because of the ‘unrecognised analogue device’ messsage, I still got the same message AFTER having put everything back together having replaced the logic board. If you shatter the back lid of the phone and have to replace it, the finger print scanner and lens covers are all prisable off and reapplicable to the new cover (with a little heating). But this requires care. Make sure to replace the battery also - because of the ka-fafel of opening this barely user-repairable phone (Cheers Google!). I ended up using gasket maker silicone (yes the stuff I use for reassembling my motorbike engine) to seal everything. Seems to have worked a treat. Good luck - you’ll need it!
Andrew Williams - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 19
Ultimi 7 Giorni: 146
Ultimi 30 Giorni: 631
Tutti i Tempi: 6,915
