Salta al contenuto principale
Google Pixel 2 Display Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Google Pixel 2 Display Replacement, Display: passo 1, immagine 1 di 2 Google Pixel 2 Display Replacement, Display: passo 1, immagine 2 di 2
    • Heat up the iOpener in the microwave for 30 seconds.
    • Place the iOpener clear-side down on each edge of the phone for approximately 30 seconds.
    • Place the iOpener on top of the screen for an additional 30 seconds.
    • Be careful with the iOpener as it will get extremely hot.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel 2 Display Replacement: passo 2, immagine 1 di 3 Google Pixel 2 Display Replacement: passo 2, immagine 2 di 3 Google Pixel 2 Display Replacement: passo 2, immagine 3 di 3
    • Attach the suction cup to the display by placing it on top of the display and pushing down on the top of the cup until it is flat.
    • Separate the display and the device by inserting the plastic opening tool between them and sliding the plastic opening tool along the perimeter of the display.
    • It is normal to hear popping noises as the plastic opening tool breaks the connection between the display and the device.
    • Remove the display from the device by grabbing the ring of the suction cup and pulling up.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel 2 Display Replacement: passo 3, immagine 1 di 3 Google Pixel 2 Display Replacement: passo 3, immagine 2 di 3 Google Pixel 2 Display Replacement: passo 3, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Remove the T4 4.0-mm screws from the latch under the display by turning the screwdriver counterclockwise.
    • Pull the latch off of the device by grabbing it with the tweezers and pulling up.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel 2 Display Replacement: passo 4, immagine 1 di 1
    • Remove the connector underneath the latch by grabbing it with the tweezers and lifting up.
    • It is normal to hear a popping noise during this step.
    • When reassembling, simply use your finger to pop this piece back into place by pushing it down into the device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team S18-G5, Livingston Winter 2018 Membro di Cal Poly, Team S18-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G5
4 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 34
Tutti i Tempi: 1,317
