Introduzione
Fix your Google Home's poor audio quality with a new sound driver.
This guide will teach you how to take apart your Google Home to remove a faulty sound driver and replace it with a new one.
Cosa ti serve
Pull off the Google Home’s magnetically attached base and set it aside.
Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
After all four screws are out, pop the lid off the device to open the capsule.
Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws on the bottom of the device.
Using a Torx T6 screwdriver head, unscrew the six black 1.7mm Torx screws on the side of the device.
Out of the the 4 corner screw one of them does not get unscrewed. Any idea. I had latest purchased Google home and one fine day I found the speaker got pushed inside and the sound has gone bad. Wanted to change the sound driver.
Altre 4 persone hanno completato questa guida.
4 Commenti
I have a torn speaker cone. Can these be replaced and where can I buy the parts
Looking for replacement speaker, where do I find?
replacement speaker for google home, someone knows here i find?
model:PLS -50N25AL07-04
or compatible speaker
