Salta al contenuto principale
Google Home Sound Driver Replacement
Cosa ti serve
  1. Google Home Sound Driver Replacement, Interconnect Cable: passo 1, immagine 1 di 3 Google Home Sound Driver Replacement, Interconnect Cable: passo 1, immagine 2 di 3 Google Home Sound Driver Replacement, Interconnect Cable: passo 1, immagine 3 di 3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Sound Driver Replacement: passo 2, immagine 1 di 1
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home Sound Driver Replacement, Mute Button Switch: passo 3, immagine 1 di 2 Google Home Sound Driver Replacement, Mute Button Switch: passo 3, immagine 2 di 2
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
  4. Google Home Sound Driver Replacement: passo 4, immagine 1 di 2 Google Home Sound Driver Replacement: passo 4, immagine 2 di 2
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
  5. Google Home Sound Driver Replacement, Motherboard: passo 5, immagine 1 di 2 Google Home Sound Driver Replacement, Motherboard: passo 5, immagine 2 di 2
    • Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
    • Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
  6. Google Home Sound Driver Replacement: passo 6, immagine 1 di 2 Google Home Sound Driver Replacement: passo 6, immagine 2 di 2
    • Using a Torx T6 screwdriver head, unscrew the five silver 1.7mm Torx screws keeping the motherboard in place.
    • Remove the motherboard.
  7. Google Home Sound Driver Replacement, Sound Driver: passo 7, immagine 1 di 2 Google Home Sound Driver Replacement, Sound Driver: passo 7, immagine 2 di 2
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws on the bottom of the device.
    • For this step you will need a T6 screwdriver with an extra long head to reach the screws.
  8. Google Home Sound Driver Replacement: passo 8, immagine 1 di 2 Google Home Sound Driver Replacement: passo 8, immagine 2 di 2
    • Using a Torx T6 screwdriver head, unscrew the six black 1.7mm Torx screws on the side of the device.
    Out of the the 4 corner screw one of them does not get unscrewed. Any idea. I had latest purchased Google home and one fine day I found the speaker got pushed inside and the sound has gone bad. Wanted to change the sound driver.
    nischal chutke - Replica
  9. Google Home Sound Driver Replacement: passo 9, immagine 1 di 2 Google Home Sound Driver Replacement: passo 9, immagine 2 di 2
    • Pull apart the black casing to reveal the sound driver.
    • Remove the sound driver.
Conclusione
Altre 4 persone hanno completato questa guida.
Gabe Hyun
Membro da: 04/17/18
826 Reputazione
4 Guide realizzate
Cal Poly, Team S24-G11, Maness Spring 2018 Membro di Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 Membri
5 Guide realizzate
4 Commenti
I have a torn speaker cone. Can these be replaced and where can I buy the parts
rchrdsmmnds - Replica
I would like to know where I can buy a replacement speaker for my Google Home. Thanks in advance P.s has anybody else had their speaker blow on them on the Google Home?
Mark Goff - Replica
Looking for replacement speaker, where do I find?
Corey Anderson - Replica
replacement speaker for google home, someone knows here i find?
model:PLS -50N25AL07-04
or compatible speaker
vinyboylima - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,048
