Salta al contenuto principale
Google Home Mute Button Switch Replacement
Cosa ti serve
  1. Google Home Mute Button Switch Replacement, Interconnect Cable: passo 1, immagine 1 di 3 Google Home Mute Button Switch Replacement, Interconnect Cable: passo 1, immagine 2 di 3 Google Home Mute Button Switch Replacement, Interconnect Cable: passo 1, immagine 3 di 3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Mute Button Switch Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home Mute Button Switch Replacement, Mute Button Switch: passo 3, immagine 1 di 2 Google Home Mute Button Switch Replacement, Mute Button Switch: passo 3, immagine 2 di 2
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
  4. Google Home Mute Button Switch Replacement: passo 4, immagine 1 di 2 Google Home Mute Button Switch Replacement: passo 4, immagine 2 di 2
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
Conclusione
Gabe Hyun
Membro da: 04/17/18
844 Reputazione
4 Guide realizzate
Cal Poly, Team S24-G11, Maness Spring 2018 Membro di Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,047
