Salta al contenuto principale
Google Home Mini USB Power Port Replacement
Cosa ti serve
  1. Google Home Mini USB Power Port Replacement, Google Home Mini Disassembly: passo 1, immagine 1 di 1
    • Place device on a flat surface.
  2. Google Home Mini USB Power Port Replacement: passo 2, immagine 1 di 1
  3. Google Home Mini USB Power Port Replacement: passo 3, immagine 1 di 1
    • Remove the lower half of the device.
    • Be careful as a black ribbon cable connects the two halves together.
  4. Google Home Mini USB Power Port Replacement: passo 4, immagine 1 di 1
    • Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
    • Flip up and push the ZIF fastener towards outside of the lower case to loosen it.
  5. Google Home Mini USB Power Port Replacement: passo 5, immagine 1 di 1
    • Pull the ribbon cable off.
  6. Google Home Mini USB Power Port Replacement, USB Power Port: passo 6, immagine 1 di 2 Google Home Mini USB Power Port Replacement, USB Power Port: passo 6, immagine 2 di 2
    • Remove the three 5.3mm T6 Torx screws from the board.
  7. Google Home Mini USB Power Port Replacement: passo 7, immagine 1 di 2 Google Home Mini USB Power Port Replacement: passo 7, immagine 2 di 2
    • Remove the black metal plate from the board.
  8. Google Home Mini USB Power Port Replacement: passo 8, immagine 1 di 2 Google Home Mini USB Power Port Replacement: passo 8, immagine 2 di 2
    • Remove the board.
Conclusione
Altre 9 persone hanno completato questa guida.
Mia Sulaiman
Membro da: 05/21/18
1.005 Reputazione
3 Guide realizzate
IUPUI, Team S1-G4, Harley Spring 2018 Membro di IUPUI, Team S1-G4, Harley Spring 2018
IUPUI-HARLEY-S18S1G4
7 Membri
5 Guide realizzate
8 Commenti
Where I can buy micro USB PCB ?
so_ang - Replica
Planet Carl - Replica
Would like to know this as well disapointing to have an instruction on how to replace a part, but nowere to buy it.
Wolve 8383 - Replica
Has anyone had any luck buying a replacement part?
Caitlin Barnum - Replica
Just broke mine :-(
Is anyone managed to find a place to buy one?
Jim - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 56
Tutti i Tempi: 5,650
