Salta al contenuto principale
Google Home Mini Speaker Replacement
Cosa ti serve
  1. Google Home Mini Speaker Replacement, Google Home Mini Disassembly: passo 1, immagine 1 di 1
    • Place device on a flat surface.
  2. Google Home Mini Speaker Replacement: passo 2, immagine 1 di 1
  3. Google Home Mini Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the lower half of the device.
    • Be careful as a black ribbon cable connects the two halves together.
  4. Google Home Mini Speaker Replacement: passo 4, immagine 1 di 1
    • Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
    • Flip up and push the ZIF fastener towards outside of the lower case to loosen it.
  5. Google Home Mini Speaker Replacement: passo 5, immagine 1 di 1
    • Pull the ribbon cable off.
  6. Google Home Mini Speaker Replacement, Speaker: passo 6, immagine 1 di 1
    • Remove the four 7.8mm T8 Torx screws.
  7. Google Home Mini Speaker Replacement: passo 7, immagine 1 di 3 Google Home Mini Speaker Replacement: passo 7, immagine 2 di 3 Google Home Mini Speaker Replacement: passo 7, immagine 3 di 3
    • The speaker will still be connected to the device.
    • Using your fingers, disconnect the wires.
Conclusione
Altre 8 persone hanno completato questa guida.
Mia Sulaiman
Membro da: 05/21/18
1.032 Reputazione
3 Guide realizzate
IUPUI, Team S1-G4, Harley Spring 2018 Membro di IUPUI, Team S1-G4, Harley Spring 2018
IUPUI-HARLEY-S18S1G4
7 Membri
5 Guide realizzate
Un commento
HI There I only have 2 lights on the google mini - and although it was working yesterday - with all 4 lights - it most certainly isn't now? I am not sure why and I am not sure what has happened?
susan woods - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 75
Tutti i Tempi: 6,989
