Salta al contenuto principale
Introduzione
A guide to disassemble Google Home Mini for further repairs.
Parti
Nessuna parte specificata.
  1. Place device on a flat surface.
    • Place device on a flat surface.
  2. Remove the rubber bottom as per the Google Home Mini teardown guide.
  3. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  4. Remove the lower half of the device.
    • Remove the lower half of the device.
    • Be careful as a black ribbon cable connects the two halves together.
  5. Using a pair of tweezers, unlatch the  Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
    • Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
    • Flip up and push the ZIF fastener towards outside of the lower case to loosen it.
    What if this breaks off. Can i direct connect power.
    Hlynur Jonasson - Replica
    Where to buy it please tell please
    Babu Vlogs - Replica
  6. Pull the ribbon cable off.
    • Pull the ribbon cable off.
Conclusione
Altre 3 persone hanno completato questa guida.
Mia Sulaiman
Membro da: 21/05/2018
549 Reputazione
3 Guide realizzate
IUPUI, Team S1-G4, Harley Spring 2018 Membro di IUPUI, Team S1-G4, Harley Spring 2018
IUPUI-HARLEY-S18S1G4
7 Membri
5 Guide realizzate
How did you get the rubber base off of it?
JAMES FLECKENSTEIN - Replica
There’s a little more explanation here
Google Home Mini Teardown
Ibby Dada -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 38
Ultimi 30 Giorni: 160
Tutti i Tempi: 1,736
