Salta al contenuto principale
Google Home Interconnect Cable Replacement
Cosa ti serve
  1. Google Home Interconnect Cable Replacement, Interconnect Cable: passo 1, immagine 1 di 3 Google Home Interconnect Cable Replacement, Interconnect Cable: passo 1, immagine 2 di 3 Google Home Interconnect Cable Replacement, Interconnect Cable: passo 1, immagine 3 di 3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Interconnect Cable Replacement: passo 2, immagine 1 di 1
    • Carefully remove the interconnect cable using a pair of tweezers.
Conclusione
Gabe Hyun
Membro da: 04/17/18
826 Reputazione
4 Guide realizzate
Cal Poly, Team S24-G11, Maness Spring 2018 Membro di Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 Membri
5 Guide realizzate
Un commento
What cord can you replace with? There is an adaptor attached.
Katti Sundelin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 677
