Salta al contenuto principale
Google Chromebook Pixel 2 Speaker Replacement
Cosa ti serve
  1. Google Chromebook Pixel 2 Speaker Replacement, Back Panel: passo 1, immagine 1 di 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. Google Chromebook Pixel 2 Speaker Replacement: passo 2, immagine 1 di 1
    • Peel off the black rubber strips from top and bottom of the back panel.
  3. Google Chromebook Pixel 2 Speaker Replacement: passo 3, immagine 1 di 2 Google Chromebook Pixel 2 Speaker Replacement: passo 3, immagine 2 di 2
    • Remove the fifteen 3 mm Phillips #00 screws from the back panel.
  4. Google Chromebook Pixel 2 Speaker Replacement: passo 4, immagine 1 di 1
    • Carefully lift the back panel off of the device.
  5. Google Chromebook Pixel 2 Speaker Replacement, Speaker: passo 5, immagine 1 di 1
    • Remove the three red 4.5 mm Phillips #00 screws from the speaker on the right sight of the motherboard.
  6. Google Chromebook Pixel 2 Speaker Replacement: passo 6, immagine 1 di 1
    • Using the plastic opening tool disconnect the speaker wires from the motherboard,
  7. Google Chromebook Pixel 2 Speaker Replacement: passo 7, immagine 1 di 1
    • Carefully remove right speaker from the device.
  8. Google Chromebook Pixel 2 Speaker Replacement: passo 8, immagine 1 di 1
    • Using the plastic opening tool, pop out the connector that joins the headphone jack port on the left side to the motherboard.
  9. Google Chromebook Pixel 2 Speaker Replacement: passo 9, immagine 1 di 1
    • Remove the red 4.5 mm Phillips #00 screw from the top of the headphone jack port.
  10. Google Chromebook Pixel 2 Speaker Replacement: passo 10, immagine 1 di 1
    • Gently remove the headphone jack port.
  11. Google Chromebook Pixel 2 Speaker Replacement: passo 11, immagine 1 di 2 Google Chromebook Pixel 2 Speaker Replacement: passo 11, immagine 2 di 2
    • Remove the three red 4.5 mm Phillips #00 screws from the speaker.
  12. Google Chromebook Pixel 2 Speaker Replacement: passo 12, immagine 1 di 1
    • Remove the left speaker.
Conclusione
Cal Poly, Team S22-G6, Livingston Spring 2017 Membro di Cal Poly, Team S22-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G6
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 88
