Salta al contenuto principale
Google Chromebook Pixel 2 Back Panel Replacement
Cosa ti serve
  1. Google Chromebook Pixel 2 Back Panel Replacement, Back Panel: passo 1, immagine 1 di 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. Google Chromebook Pixel 2 Back Panel Replacement: passo 2, immagine 1 di 1
    • Peel off the black rubber strips from top and bottom of the back panel.
  3. Google Chromebook Pixel 2 Back Panel Replacement: passo 3, immagine 1 di 2 Google Chromebook Pixel 2 Back Panel Replacement: passo 3, immagine 2 di 2
    • Remove the fifteen 3 mm Phillips #00 screws from the back panel.
  4. Google Chromebook Pixel 2 Back Panel Replacement: passo 4, immagine 1 di 1
    • Carefully lift the back panel off of the device.
Conclusione
Cal Poly, Team S22-G6, Livingston Spring 2017 Membro di Cal Poly, Team S22-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G6
4 Membri
3 Guide realizzate
Un commento
Where can I buy replacements for the rubber strips? They never quite fit again and eventually were coming off and sticking to things, so had to throw them away.
Marc Bernard Schauber - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,402
