Salta al contenuto principale
Golf Club Grip Replacement
Cosa ti serve
  1. Golf Club Grip Replacement, Grip: passo 1, immagine 1 di 2 Golf Club Grip Replacement, Grip: passo 1, immagine 2 di 2
    • Place the golf club securely on a level table.
    • Using a blade or knife, cut a line through the grip.
  2. Golf Club Grip Replacement: passo 2, immagine 1 di 3 Golf Club Grip Replacement: passo 2, immagine 2 di 3 Golf Club Grip Replacement: passo 2, immagine 3 di 3
    • Remove the grip from the golf club shaft.
  3. Golf Club Grip Replacement: passo 3, immagine 1 di 1
    • Use the knife to take off any excess residue from the shaft of the club.
  4. Golf Club Grip Replacement: passo 4, immagine 1 di 2 Golf Club Grip Replacement: passo 4, immagine 2 di 2
    • Apply the double sided tape to the bare shaft in a spiral pattern.
    • Use the grip to determine how far up the shaft the tape needs to go.
  5. Golf Club Grip Replacement: passo 5, immagine 1 di 1
    • Remove the tape backing.
  6. Golf Club Grip Replacement: passo 6, immagine 1 di 3 Golf Club Grip Replacement: passo 6, immagine 2 di 3 Golf Club Grip Replacement: passo 6, immagine 3 di 3
    • Place a golf tee in the hole at the end of the golf grip.
  7. Golf Club Grip Replacement: passo 7, immagine 1 di 2 Golf Club Grip Replacement: passo 7, immagine 2 di 2
    • Pour a generous amount of adhesive into the opposite end of the grip.
    • Squeeze together the open end of the grip.
    • Lightly shake, in order to spread the adhesive within the grip.
  8. Golf Club Grip Replacement: passo 8, immagine 1 di 1
    • Over a bowl or container, pour adhesive in the grip onto the shaft of the golf club.
  9. Golf Club Grip Replacement: passo 9, immagine 1 di 2 Golf Club Grip Replacement: passo 9, immagine 2 di 2
    • Remove the tee from the back of the grip.
    • Push the grip onto the golf club shaft.
    • Ensure that the end of the grip is hitting the end of the shaft.
  10. Golf Club Grip Replacement: passo 10, immagine 1 di 1
    • Allow to dry at least 12 hours before use.
Conclusione
After allowing the club to properly dry, you will have a new grip to improve your swing at tee off.
Altre 6 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 45
Tutti i Tempi: 7,361
