Salta al contenuto principale
GoPro Karma Stabilizer Replacement
  1. GoPro Karma Stabilizer Replacement, Stabilizer: passo 1, immagine 1 di 3 GoPro Karma Stabilizer Replacement, Stabilizer: passo 1, immagine 2 di 3 GoPro Karma Stabilizer Replacement, Stabilizer: passo 1, immagine 3 di 3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  2. GoPro Karma Stabilizer Replacement: passo 2, immagine 1 di 1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
Conclusione
Cal Poly, Team S25-G14, Maness Spring 2018 Membro di Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Membri
6 Guide realizzate
Un commento
My karma got accident and broke two arms on right side. But I tried to start it again and not working anymore.
Friday Aringo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,896
