Salta al contenuto principale
GoPro Karma Propeller Replacement
  1. GoPro Karma Propeller Replacement, Battery: passo 1, immagine 1 di 1
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Propeller Replacement, Stabilizer: passo 2, immagine 1 di 3 GoPro Karma Propeller Replacement, Stabilizer: passo 2, immagine 2 di 3 GoPro Karma Propeller Replacement, Stabilizer: passo 2, immagine 3 di 3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Propeller Replacement: passo 3, immagine 1 di 1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Propeller Replacement, Propeller: passo 4, immagine 1 di 3 GoPro Karma Propeller Replacement, Propeller: passo 4, immagine 2 di 3 GoPro Karma Propeller Replacement, Propeller: passo 4, immagine 3 di 3
    • Extend the arms and set the drone face up.
    • The front right and back left propellers unscrew clockwise.
    • The front left and back right propellers unscrew counterclockwise.
  5. GoPro Karma Propeller Replacement: passo 5, immagine 1 di 2 GoPro Karma Propeller Replacement: passo 5, immagine 2 di 2
    • Place the GoPro Karma wrench on the motor.
    • Hold the motor in place with the wrench and unscrew the propeller in the indicated direction.
Conclusione
Jay Ingram
Membro da: 04/19/18
334 Reputazione
3 Guide realizzate
Cal Poly, Team S25-G14, Maness Spring 2018 Membro di Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Membri
6 Guide realizzate
2 Commenti
You got it the wrong way around, to take them off you need to do the exact opposite to what you say.
michael.woelk - Replica
hi, i am trying to fix my Karma. I have to remove the propellers but it is like they are stocked.
I try to unscrew the propellers but i can’t remove them.
Do you know what to do in this case?
Davide Negro - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,623
