Salta al contenuto principale
GoPro Karma Landing Gear Replacement
Cosa ti serve
  1. GoPro Karma Landing Gear Replacement, Battery: passo 1, immagine 1 di 1
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Landing Gear Replacement, Stabilizer: passo 2, immagine 1 di 3 GoPro Karma Landing Gear Replacement, Stabilizer: passo 2, immagine 2 di 3 GoPro Karma Landing Gear Replacement, Stabilizer: passo 2, immagine 3 di 3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Landing Gear Replacement: passo 3, immagine 1 di 1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Landing Gear Replacement, Landing Gear: passo 4, immagine 1 di 1
    • Flip the drone upside down with the landing gear out.
    • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
  5. GoPro Karma Landing Gear Replacement: passo 5, immagine 1 di 1
    • Push with your thumb and pull up with your fingers to remove the landing gear.
    • Caution: The landing gear is connected by a thin cable so do not pull too far away.
  6. GoPro Karma Landing Gear Replacement: passo 6, immagine 1 di 2 GoPro Karma Landing Gear Replacement: passo 6, immagine 2 di 2
    • Flip over the landing gear and locate the cable connector.
    • Use your thumbnail to disconnect the cable and free the landing gear.
Conclusione
Jay Ingram
Membro da: 04/19/18
334 Reputazione
3 Guide realizzate
Cal Poly, Team S25-G14, Maness Spring 2018 Membro di Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 616
