Introduzione
Use this guide to remove and replace your broken landing gear. It will show you how to remove the entire assembly safely for replacement. This may be needed if broken on a rough landing.
Cosa ti serve
Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
