Salta al contenuto principale
GoPro Karma Arms Replacement
Cosa ti serve
  1. GoPro Karma Arms Replacement, Battery: passo 1, immagine 1 di 1
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Arms Replacement, Stabilizer: passo 2, immagine 1 di 3 GoPro Karma Arms Replacement, Stabilizer: passo 2, immagine 2 di 3 GoPro Karma Arms Replacement, Stabilizer: passo 2, immagine 3 di 3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Arms Replacement: passo 3, immagine 1 di 1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Arms Replacement, Landing Gear: passo 4, immagine 1 di 1
    • Flip the drone upside down with the landing gear out.
    • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
  5. GoPro Karma Arms Replacement: passo 5, immagine 1 di 1
    • Push with your thumb and pull up with your fingers to remove the landing gear.
    • Caution: The landing gear is connected by a thin cable so do not pull too far away.
  6. GoPro Karma Arms Replacement: passo 6, immagine 1 di 2 GoPro Karma Arms Replacement: passo 6, immagine 2 di 2
    • Flip over the landing gear and locate the cable connector.
    • Use your thumbnail to disconnect the cable and free the landing gear.
  7. GoPro Karma Arms Replacement, Arms: passo 7, immagine 1 di 1
    • Remove the two 1.2 cm long hex screws with a Hex 2.0 screwdriver and set them aside.
  8. GoPro Karma Arms Replacement: passo 8, immagine 1 di 2 GoPro Karma Arms Replacement: passo 8, immagine 2 di 2
    • Remove both locked connectors by pushing the connector release tool into the hole in the center and pulling up with the white handles.
    • The connector release tool is only included with the purchase of a replacement arm from the GoPro website.
    • If you do not have a connector release tool, use a small screwdriver to push each tab while pulling up with the white handles.
  9. GoPro Karma Arms Replacement: passo 9, immagine 1 di 3 GoPro Karma Arms Replacement: passo 9, immagine 2 di 3 GoPro Karma Arms Replacement: passo 9, immagine 3 di 3
    • Remove the cover plate by pulling up on the side.
    • Feed each connector through the hole and set aside the cover plate.
  10. GoPro Karma Arms Replacement: passo 10, immagine 1 di 2 GoPro Karma Arms Replacement: passo 10, immagine 2 di 2
    • Loosen the 2 cm long hex screw in the arm with a Hex 2.0 screwdriver.
    • The screw will not come out but loosen it until it can rotate easily.
    • Pull up and off the broken arm.
Conclusione
Kyle Hoff
Membro da: 04/23/18
141 Reputazione
1 Guida realizzata
Cal Poly, Team S25-G14, Maness Spring 2018 Membro di Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,195
