Introduzione
In this guide, you will be removing the battery housing from the back housing. The GoPro Hero5 Black is waterproofed with plenty of adhesives. By completing this guide, you will have to remove the adhesive and your GoPro will no longer be waterproof.
Cosa ti serve
While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
Refer to the iOpener instructions for how to heat up and use the iOpener.
Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
Remove the 3mm #000 Phillips screw.
Remove the 2mm #000 Phillips screw.
Altre 10 persone hanno completato questa guida.
Un commento
Is there any glue to use to make the case waterproof again?
