Salta al contenuto principale
GoPro Hero4 Silver Front Panel Replacement
Cosa ti serve
  1. GoPro Hero4 Silver Front Panel Replacement, Front Panel: passo 1, immagine 1 di 3 GoPro Hero4 Silver Front Panel Replacement, Front Panel: passo 1, immagine 2 di 3 GoPro Hero4 Silver Front Panel Replacement, Front Panel: passo 1, immagine 3 di 3
    • Start by removing the silver plastic face from the camera using a plastic opening tool. Insert the plastic opening tool into the middle of each edge and lift up the tabs that keep the camera face on.
    • The seven plastic tab locations are marked in red.
    • Try using the plastic opening tool before switching to the metal spudger. We tried using the plastic opening tool to pry the camera face off, but found that it did not give us enough leverage.
    • There may be glue holding the camera face on to the housing. Be careful not to flex the camera face too much, or it will crack.
    First step should be make sure you remove memory card first. I accidentally left mine and broke it trying to remove the assembly from the case.
    Brad Hodgkinson - Replica
Conclusione
Altre 15 persone hanno completato questa guida.
Zack Hoover
Membro da: 08/27/15
1.109 Reputazione
3 Guide realizzate
USF Tampa, Team 2-1, Blackwell Fall 2015 Membro di USF Tampa, Team 2-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G1
4 Membri
20 Guide realizzate
2 Commenti
Am I mistaken, or are there missing steps in this guide?
Tom Fox - Replica
Looks like a simple remove/replace guide. Only one step needed.
justincarver - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 35
Tutti i Tempi: 11,319
