Salta al contenuto principale
GoPro Hero4 Black Camera Sensor Replacement
Cosa ti serve
  1. GoPro Hero4 Black Camera Sensor Replacement, Midframe Housing: passo 1, immagine 1 di 3 GoPro Hero4 Black Camera Sensor Replacement, Midframe Housing: passo 1, immagine 2 di 3 GoPro Hero4 Black Camera Sensor Replacement, Midframe Housing: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
    • Use the tweezers to lift the faceplate from the rest of the device.
    • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
  2. GoPro Hero4 Black Camera Sensor Replacement: passo 2, immagine 1 di 2 GoPro Hero4 Black Camera Sensor Replacement: passo 2, immagine 2 di 2
    • Using a #00 Phillips head screwdriver, remove the following screws:
    • One 4.6 mm screw
    • Three 8.2 mm screws
    • Two 6.1 mm screws
  3. GoPro Hero4 Black Camera Sensor Replacement: passo 3, immagine 1 di 2 GoPro Hero4 Black Camera Sensor Replacement: passo 3, immagine 2 di 2
    • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
  4. GoPro Hero4 Black Camera Sensor Replacement: passo 4, immagine 1 di 3 GoPro Hero4 Black Camera Sensor Replacement: passo 4, immagine 2 di 3 GoPro Hero4 Black Camera Sensor Replacement: passo 4, immagine 3 di 3
    • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
    • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
    • The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
    • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
  5. GoPro Hero4 Black Camera Sensor Replacement, Camera Sensor: passo 5, immagine 1 di 3 GoPro Hero4 Black Camera Sensor Replacement, Camera Sensor: passo 5, immagine 2 di 3 GoPro Hero4 Black Camera Sensor Replacement, Camera Sensor: passo 5, immagine 3 di 3
    • Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
  6. GoPro Hero4 Black Camera Sensor Replacement: passo 6, immagine 1 di 3 GoPro Hero4 Black Camera Sensor Replacement: passo 6, immagine 2 di 3 GoPro Hero4 Black Camera Sensor Replacement: passo 6, immagine 3 di 3
    • Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor.
Conclusione
Altre 7 persone hanno completato questa guida.
USF Tampa, Team S2-G1, Sullivan Spring 2017 Membro di USF Tampa, Team S2-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G1
4 Membri
12 Guide realizzate
2 Commenti
not easy to return the ribbon back to its place! it’s easier to throw your gopro after doing this.
popoypoi22 - Replica
Hi, is the sensor for black and silver same? Thank you
Jakub Kunický - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 19
Tutti i Tempi: 3,907
