Salta al contenuto principale
GoPro Hero3+ Silver Edition Image Sensor Replacement
Cosa ti serve
  1. GoPro Hero3+ Silver Edition Image Sensor Replacement, Battery: passo 1, immagine 1 di 2 GoPro Hero3+ Silver Edition Image Sensor Replacement, Battery: passo 1, immagine 2 di 2
    • Push the tab on the back of the device left to remove the plate covering the battery.
    Chiedi a FixBot
    Aggiungi Commento
  2. GoPro Hero3+ Silver Edition Image Sensor Replacement: passo 2, immagine 1 di 1
    • Use the strip of tape on the battery to remove the battery from the housing.
    Chiedi a FixBot
    Aggiungi Commento
  3. GoPro Hero3+ Silver Edition Image Sensor Replacement, Front Panel: passo 3, immagine 1 di 1
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
    Chiedi a FixBot
    Aggiungi Commento
  4. GoPro Hero3+ Silver Edition Image Sensor Replacement: passo 4, immagine 1 di 1
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
    Chiedi a FixBot
    Aggiungi Commento
  5. GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: passo 5, immagine 1 di 3 GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: passo 5, immagine 2 di 3 GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: passo 5, immagine 3 di 3
    • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
    • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
    • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  6. GoPro Hero3+ Silver Edition Image Sensor Replacement: passo 6, immagine 1 di 2 GoPro Hero3+ Silver Edition Image Sensor Replacement: passo 6, immagine 2 di 2
    • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
    Chiedi a FixBot
    Aggiungi Commento
  7. GoPro Hero3+ Silver Edition Image Sensor Replacement: passo 7, immagine 1 di 1
    • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  8. GoPro Hero3+ Silver Edition Image Sensor Replacement: passo 8, immagine 1 di 2 GoPro Hero3+ Silver Edition Image Sensor Replacement: passo 8, immagine 2 di 2
    • Pry off the last ribbon cable with a plastic opening tool.
    • Remove the image sensor from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 5-8, Maness Fall 2015 Membro di Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 31
Tutti i Tempi: 1,174
