Salta al contenuto principale
GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement
Cosa ti serve
  1. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Casing: passo 1, immagine 1 di 1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: passo 2, immagine 1 di 1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: passo 3, immagine 1 di 1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: passo 4, immagine 1 di 1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: passo 5, immagine 1 di 1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: passo 6, immagine 1 di 1
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Micro USB/MicroSD Card Daughter Board: passo 7, immagine 1 di 2 GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Micro USB/MicroSD Card Daughter Board: passo 7, immagine 2 di 2
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
  8. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: passo 8, immagine 1 di 1
    • Remove the two screws located on each side of the board with a Phillips screwdriver.
    • The screws go through an L metal bracket that will come off with the screws.
  9. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: passo 9, immagine 1 di 1
    • Separate the daughter board from the white plastic piece.
Conclusione
Altre 5 persone hanno completato questa guida.
River Drake
Membro da: 04/02/15
1.047 Reputazione
5 Guide realizzate
Cal Poly, Team 12-2, Lancaster Spring 2015 Membro di Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Membri
18 Guide realizzate
4Commenti sulla guida
Wo kann ich ein daughterboard kaufen habt ihr da was für mich?
Lukas Blohm - Replica
bravo! è scritto molto bene ed è stato utile. ma dove trovo il ricambio? non ci riesco!!!
michele - Replica
Terrific guide. Does anyone know where to buy the “daughter board”?
fedebossert - Replica
fedebossert - 05/27/20
<a href="https://www.w3schools.com/">Visit W3Schools.com!</a>
pavan kalyan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 5,161
