Salta al contenuto principale
GoPro Hero Lens Replacement
Cosa ti serve
  1. GoPro Hero Lens Replacement, Casing: passo 1, immagine 1 di 1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Lens Replacement: passo 2, immagine 1 di 1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Lens Replacement: passo 3, immagine 1 di 1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero Lens Replacement: passo 4, immagine 1 di 1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero Lens Replacement: passo 5, immagine 1 di 1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero Lens Replacement: passo 6, immagine 1 di 1
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero Lens Replacement, Lens: passo 7, immagine 1 di 1
    • Remove the four screws from the lens.
    • These screws are smaller than the ones removed from the white plastic piece.
  8. GoPro Hero Lens Replacement: passo 8, immagine 1 di 1
    • Remove the lens from the case.
Conclusione
To reassemble your device, follow the instructions in reverse order.
Altre 3 persone hanno completato questa guida.
River Drake
Membro da: 04/02/15
1.047 Reputazione
5 Guide realizzate
Cal Poly, Team 12-2, Lancaster Spring 2015 Membro di Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Membri
18 Guide realizzate
1Commento della guida
I followed this list, but I think I knocked a component off of the motherboard while I was unscrewing it. I wasn’t planning on ever putting it back together, since I have a newer GoPro camera. Luckily, the lens and the cable connecting it didn’t get damaged. Is there maybe a way to connect the lens to the Raspberry Pi Zero?
Doggo Boi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 37
Tutti i Tempi: 13,601
