Introduzione
If for some reason, your screen is dysfunctional, you can replace it. Since it is near the bottom of the camera, it is not easy to replace. Grab your screwdrivers and tweezers and let's go!
Cosa ti serve
Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
Altre 5 persone hanno completato questa guida.
3 Commenti
Where do you buy the replacement lcd
Gopro hero 7 white repair cost:
Screen: $45 - https://www.ebay.com.au/itm/183828969944
Side panel: $35 - https://www.herogear.com.au/genuine-repl...
I can find the screen but is it compatible with the Hero+
