Salta al contenuto principale
GoPro Hero+ LCD Lens Replacement
Cosa ti serve
  1. GoPro Hero+ LCD Lens Replacement, Back Panel: passo 1, immagine 1 di 2 GoPro Hero+ LCD Lens Replacement, Back Panel: passo 1, immagine 2 di 2
    • Be sure to power off the GoPro before you start disassembly.
    • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
  2. GoPro Hero+ LCD Lens Replacement: passo 2, immagine 1 di 2 GoPro Hero+ LCD Lens Replacement: passo 2, immagine 2 di 2
    • Use the metal spudger to pry around the perimeter of the panel.
    • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
  3. GoPro Hero+ LCD Lens Replacement: passo 3, immagine 1 di 2 GoPro Hero+ LCD Lens Replacement: passo 3, immagine 2 di 2
    • Pry around the panel to ensure it is not attached to the device.
    • Move the panel to the side so you can access the internal components.
    • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
  4. GoPro Hero+ LCD Lens Replacement, Battery: passo 4, immagine 1 di 1
    • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
    • Be careful of metal contacts on strip; they can be sharp.
  5. GoPro Hero+ LCD Lens Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, peel off the copper tape on the right side of the battery.
  6. GoPro Hero+ LCD Lens Replacement: passo 6, immagine 1 di 2 GoPro Hero+ LCD Lens Replacement: passo 6, immagine 2 di 2
    • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
  7. GoPro Hero+ LCD Lens Replacement: passo 7, immagine 1 di 1
    • Use a pair of tweezers to disconnect the battery connector from the motherboard.
    • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
  8. GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: passo 8, immagine 1 di 3 GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: passo 8, immagine 2 di 3 GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: passo 8, immagine 3 di 3
    • Remove the two 6 mm Phillips #00 screws.
    • Remove the single 4 mm Phillips #000 screws.
  9. GoPro Hero+ LCD Lens Replacement: passo 9, immagine 1 di 1
    • Remove the image sensor from the camera.
    • You do not have to unplug the black box to remove the USB/SD chip.
  10. GoPro Hero+ LCD Lens Replacement: passo 10, immagine 1 di 1
    • Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
    • Be careful when removing the ribbon cable. You must pull gently or you can rip the ribbon off of its contacts.
  11. GoPro Hero+ LCD Lens Replacement: passo 11, immagine 1 di 1
    • Gently lift the microSD/Micro USB assembly up and out of the device.
  12. GoPro Hero+ LCD Lens Replacement, Image Sensor: passo 12, immagine 1 di 1
    • Use your fingers and gently pull out the sensor from the motherboard by slowly and gradually pulling up on the image sensor box.
    • Do not yank on the image sensor, it can rip out the wiring or damage the motherboard.
  13. GoPro Hero+ LCD Lens Replacement, Motherboard: passo 13, immagine 1 di 3 GoPro Hero+ LCD Lens Replacement, Motherboard: passo 13, immagine 2 di 3 GoPro Hero+ LCD Lens Replacement, Motherboard: passo 13, immagine 3 di 3
    • Remove the three 4 mm Phillips #000 screws securing the motherboard.
  14. GoPro Hero+ LCD Lens Replacement: passo 14, immagine 1 di 1
    • Use your fingers to gently remove the ribbon connected to the lens.
    • Be careful when removing the ribbon cable. Pull off gently or you can separate the ribbon from the contacts.
  15. GoPro Hero+ LCD Lens Replacement: passo 15, immagine 1 di 3 GoPro Hero+ LCD Lens Replacement: passo 15, immagine 2 di 3 GoPro Hero+ LCD Lens Replacement: passo 15, immagine 3 di 3
    • Use your fingers and carefully pull out the motherboard from under the lens. It may take a little bit of adjusting to get it out.
  16. GoPro Hero+ LCD Lens Replacement, Lens: passo 16, immagine 1 di 3 GoPro Hero+ LCD Lens Replacement, Lens: passo 16, immagine 2 di 3 GoPro Hero+ LCD Lens Replacement, Lens: passo 16, immagine 3 di 3
    • Remove the two 4 mm Phillips #000 screws securing the top button.
  17. GoPro Hero+ LCD Lens Replacement: passo 17, immagine 1 di 2 GoPro Hero+ LCD Lens Replacement: passo 17, immagine 2 di 2
    • Remove the four 4 mm Phillips #000 screws securing the lens to the case.
  18. GoPro Hero+ LCD Lens Replacement: passo 18, immagine 1 di 3 GoPro Hero+ LCD Lens Replacement: passo 18, immagine 2 di 3 GoPro Hero+ LCD Lens Replacement: passo 18, immagine 3 di 3
    • Gently lift the lens up and out of the device.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 2-4, Blackwell Fall 2015 Membro di USF Tampa, Team 2-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G4
4 Membri
20 Guide realizzate
2Commenti sulla guida
I'm curious if you have any suggestions for sourcing the replacement part.
Driftless Repair - Replica
My hing clip is broken, Can I remove the actual camera & replace the full waterproof case then reinstall my camera into the new replacement case ?
jimmac044 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 32
Tutti i Tempi: 6,952
